Lifted truck front end alignment
Old 05-26-2001, 08:46 PM
Ford4ever's Avatar
Post Lifted truck front end alignment
Where do you guys get your lifted trucks aligned? None of the places here will do it because they don't have the specs for trucks with suspension lifts. I talked one place into doing it, they worked on it for 2 hours, actually i went out there and did most of the work because the techs didn't know crap about twin I-beam suspension. I did the camber and caster adjustments and assumed they could figure out how to set toe. However they never did get the thing to drive straight. They gave me a refund and i came home and aligned it in my driveway. I have it set so the steering wheel is straight and it doesn't pull but i don't know yet if it will wear tires (and swampers are expensive!). Where did you guys get your trucks aligned?
-Jon
Quick Reply: Lifted truck front end alignment
