seprntine belt routing diagram???
Old 09-24-2003, 07:11 PM
ryan@nmra's Avatar
Does anyone have a belt diagram for a 1991 F150 with a 302 using the serpentine belt system. I had to change the radiator in my dads truck and it doesnt have a routing diagram on the shroud or under the hood, chiltons absolutely did no good whatsoever, it only shows routing diagram for a V belt system, thanks in advance.
Ryan
Old 09-25-2003, 12:30 PM
ryan@nmra's Avatar
Anyone?????
Old 09-25-2003, 01:47 PM
Throttle's Avatar
diagram
Since we can no longer attach, send me your e-mail address and I will forward it in MS Paint (BMP) format.
Old 09-25-2003, 06:49 PM
ryan@nmra's Avatar
Thank you Throttle, I appreciate it very much.
Ryan
2l8uluz@tampabay.rr.com
Old 07-01-2004, 07:57 PM
Dragonsys's Avatar
Do you still have that image? I need it to...
webmaster@dragonsys.org
Old 07-01-2004, 08:36 PM
temp1's Avatar
Does it look something like this?
Old 07-02-2004, 10:43 AM
Johngs's Avatar
A 302 is the 5.0L engine, so that diagram probably wont work.
Old 07-02-2004, 01:27 PM
temp1's Avatar
Good point! Maybe it looks more like this?
Old 12-27-2005, 04:49 PM
bsincs's Avatar
Question
Can someone repost the picture for the 5.0 belt routing? Thanks in advance for the help.
Old 12-27-2005, 05:10 PM
sdtsdt's Avatar
One thing you can do is look at the surfaces ...back of belt goes on smooth surface rollers ... belt ridges goes across pulleys with ridges ... You can probably sort if out ...visually start with tensionor and work the paths from there ... Then install belt reversing that path ending at tensionor
Quick Reply: seprntine belt routing diagram???
