Got my 1st Ford truck, Does my 1992 F150/302 have an AOD-E, AOD, or a diff. trans?
Old 02-05-2004, 07:23 PM
MustangFergy's Avatar
Thumbs up Got my 1st Ford truck, Does my 1992 F150/302 have an AOD-E, AOD, or a diff. trans?
Hey,
I have a built AOD from my Mustang (I'm changing it to a 5 speed). It has heavy duty clutches, better servo, better O/D band, and a Transgo shiftkit. Will this transmission work in my 92 Ford F150?
Mine has the "O/D" switch on the shifter handle,
so is it the AOD or AODE? or another transmission?
if it's an AOD-E, would my AOD work intead of the AODE if it went bad?
I may be selling the AOD on Corral, but I'm not getting half of what I have into it, so it may be worth it to keep it for the truck. Thanks for your help!
(PS: I plan on doing some engine mods when my Mustang project gets done for now)
Old 02-05-2004, 08:22 PM
powerstroke73's Avatar
As I recall your F150 would have an AODE in it. Keep in mind that if your truck is 4x4 your stang tranny won't work due to the married transfer case setup.
Old 02-06-2004, 01:50 PM
Whitetrash SVT's Avatar
That truck has the E4OD trans. The AOD-E was not introduced until '93.
-Jim
Old 02-06-2004, 10:47 PM
so since it's a 2wd, would an AOD work? I mean, I'd say so, but maybe I'm missing something
Old 02-07-2004, 09:56 AM
I honestly don't know, I've never done a swap like that. You will definitely need a TV cable, TV cable throttle bracket, linkage and possibly the drive shaft and crossmember from a pre 1990 F-150. Remember, the most important thing is not to quote me on this.
Your t-body should still have the arm to clip the TV cable onto.
-Jim
Old 02-07-2004, 04:57 PM
ok, so my transmission doesn't use a TV/kick down cable?
Worse case scenario, I'd use a manual valvebody, as I hate those stupid kick down cables, due to one of them failing, it cost me $1,411.30
Oh well, lessons learned
Old 02-08-2004, 06:45 PM
You need the cable to properly regulate line pressure. It can't compensate for extra load without it.
Quick Reply: Got my 1st Ford truck, Does my 1992 F150/302 have an AOD-E, AOD, or a diff. trans?
