clutch stuck in disengagement
Old 05-02-2004, 09:57 PM
rx8's Avatar
rx8
rx8 is offline
my clutch is stuck , disengaged
can anybody help with answers, its a 95 w 5 speed manual
Old 05-03-2004, 01:37 PM
JMC's Avatar
JMC
JMC is offline
Is the clutch pedal still depressed and stuck on the floor or is it back in the normal position? If the clutch pedal is not stuck is it hard to move. If it is stuck on the floor I would look for something binding in the pedal linkage, between the pedal and the master cylinder. If it is not depressed I would still look at the linkage and if that checks out I suspect the fingers on the clutch pressure plate are damaged.
Regards
Jean Marc Chartier
Old 05-04-2004, 01:56 AM
rx8's Avatar
rx8
rx8 is offline
Thanks for the reply JMC, I just pulled the clutch master and found that the clutch assembly; slave, bearing, pressure plate and disk, are stuck (jammed ?) forward.
Managed to make it to NAPA today and bought new master, slave and hd clutch kit. Hope to make it home early enough tomorrow to start wrenching on it.
Pls wish me luck, I'll need it!!
PS, look like you have a real nice ride there, was just about to order some GT 40 heads for mine but this damn clutch seems to have gotten in the way.
thanks again Stan
Old 05-04-2004, 11:08 AM
JMC's Avatar
JMC
JMC is offline
That sucks. I have had to replace 3 slave cylinders for leaking problems. A real PITA becasue of 4x4 T-case.
JMC
Old 05-07-2004, 11:13 AM
rx8's Avatar
rx8
rx8 is offline
The slave clyindeer was bound up solid!!!
All new parts now and trued up the flywheel, clutch is soomth as silk.
Thanks again JMC
Stan
Quick Reply: clutch stuck in disengagement
