1997 Ford F150 Fuse Box Diagram
Old 05-07-2004, 05:53 PM
thebaby79's Avatar
Exclamation 1997 Ford F150 Fuse Box Diagram
My horn and Cruise controll quit working and I am pretty sure it is a fuse. I do not have an owners manual. I thought Id spare myself going through every fuse and ask... Which fuse is for the horn and cruise controll? My boyfriend thinks I broke the steering wheel mechanisims somehow when I dented the front bumper. Please help me prove him wrong and fix the fuse at the same time. : )
Old 05-07-2004, 07:50 PM
JMC's Avatar
JMC
JMC is offline
Sorry to dissapoint you but the horn fuse is in the Power Distribution Box #5 20amp
in the engine compartment and the cruise fuse is #5 15amp in the Junction Box inside the cab behind the panel in the lower dash. This fuse also controls the DRL if you have them and the Function Selector Swich for the AC. I suspect either the clock spring as your boyfriend suggests or the connector to it. It may have ben jarred loose if it was not properly seated. It is at the base of the steering column, it has 6 terminals and it is brown.
BTW how hard did you hit to dent the bumper?
Regards
Jean Marc Chartier
Quick Reply: 1997 Ford F150 Fuse Box Diagram
