Supercharger for the 5.4L engines!!!!
Old 05-08-2004, 07:10 PM
deceptikon's Avatar
Ran into this on ebay..Would this fit on our trucks?
SVT
Old 05-08-2004, 07:37 PM
deceptikon's Avatar
Dont everyone answer at once.....
Old 05-08-2004, 07:55 PM
ieee_raider's Avatar
I can't say for sure, but I believe the old 5.4 had a different intake on it. So, maybe not.
You might look around for a pic of the old 5.4 and see if it at least appears to be the same.
Old 05-08-2004, 08:12 PM
max mitchell's Avatar
There are no parts to fit this on the redesigned 2004 5.4 3-valve F-150. After several years, a few people are finally getting the basic installation of this figured out for the last model non-supercharged 5.4.
Old 05-08-2004, 08:13 PM
IzInBloOm's Avatar
tough call. Depends how close the 3V heads are to the 2V heads.
For sure you'd have to get a different intake manifold. To mount that "Roots type" supercharger you need a metal manifold designed to mate up to it - Look at the underside.
You would also need to change the Crank pully (double) and add some brakets for a tensioner for the extra belt.
And you would need some recalibration too obviously.
-ii
Old 05-08-2004, 10:47 PM
BrewMaster's Avatar
it's not meant for the 2004 F-150 3V engine. no need to get all excited. move along, this is not the blower you are looking for...
Old 05-09-2004, 07:31 PM
Sithor's Avatar
This is the supercharger you are looking for. http://www.whipplesuperchargers.com/...sp?ProdID=1203
Old 05-09-2004, 08:05 PM
ristuccia's Avatar
where can i buy that whipple supercharger? i cant find an online dealer or it.
Old 05-09-2004, 08:38 PM
positron's Avatar
in this months StreetTrucks magazine, there is an article about installing a kenn belle supercharger for the 5.4 3valve F-150. after the modit gets 445 HP @3750rpm and 529Ft-LBs. of torque
not bad for a mod for $3,899
Old 05-10-2004, 07:51 AM
positron's Avatar
after reading the article again , I found that kenne bell only needs an extra belt from the alternator to the supercharger unit. it looks like an easy install.
http://www.kennebell.net/
Quick Reply: Supercharger for the 5.4L engines!!!!
