Fuel Injection swap to Carb.
Old 05-24-2004, 02:09 PM
GMKiller's Avatar
I have a 91 F-150 5.0 with an AOD Fuel Injection. I want to go to an 87 351w Carb. Engine. I need to know all the changes necessary to swap them out. Electrical, computer, mounts, etc.
Any Help Greatly appreciated.
Old 06-14-2004, 12:50 AM
urldzynr's Avatar
carbing a fuel inj. motor??
but . . . WHY??, everyone knows that direct fuel injection is hands and feet above carbs. if you're looking to pump more volume into the chambers then look for some 24lb. injectors, you can still use the same fuel rail w/o any troubles. if you go near the 32lb range, you will have to change the rails, and that process can get a bit spendy, esp if you have to take the machine out to get the computer flashed . . .
Quick Reply: Fuel Injection swap to Carb.
