Check engine P0405 diff. EGR problem?
Old 05-24-2004, 02:55 PM
BPatin's Avatar
Question Check engine P0405 diff. EGR problem?
I have the P0405 code on my 4.6 liter 2002 F150. Is this the same problem as all the other EGR posts? Do I need to try to clean it ? or replace it??
Brian
Old 05-24-2004, 03:58 PM
temp1's Avatar
It seems strange that you would get a p0405 code for an F150. How did you get the p0405 code and was it the only code retrieved? p0405 would indicate that we have an electronic EGR valve on our trucks which we don't.
Maybe you really got a p1405 which points to the DPFE sensor?
https://www.f150online.com/forums/sh...ighlight=p1405
Old 05-26-2004, 06:33 PM
BPatin's Avatar
This is the code that came up on the unit the guy at Auto Zone used???????????
Brian
Old 05-26-2004, 08:39 PM
temp1's Avatar
Did you write the code down or are you going from memory?
Old 06-08-2004, 06:37 PM
BPatin's Avatar
I went to another repair shop and checked the code again. P0405 I saw it ans wrote it down myself!
Brian Patin
Old 06-08-2004, 07:26 PM
temp1's Avatar
Brian Patin
Do you have some sort of electrical harness connector on your EGR valve?
How many miles are on your truck?
I have seen a couple of posts that say 95% of EGR related problems are due to bad DPFE sensors.
Old 06-08-2004, 08:13 PM
lifeguardjoe's Avatar
Yes, getting the P0405 code is possible, many people have gotten it before, this is old news. Just follow these instructions and you should be fine...
http://www.fordf150.net/howto/throttlebodyclean.php
Old 06-08-2004, 09:35 PM
temp1's Avatar
Lifeguardjoe,
I did a search for p0405 and only one thread. Where did these folks post about the p0405 code?
Old 06-09-2004, 09:55 PM
STAN/SRMASTER's Avatar
P0405 - DPF EGR Sensor Circuit Low Voltage Detected. This code is set when DPFE sensor voltage drops below .2 volt. Plugged EGR ports will not cause this. This is caused by a bad DPFE sensor 99.99% of the time. Being a FORD tech, I have seen this code many times.
Old 06-10-2004, 05:51 AM
BPatin's Avatar
Thanks for the replys. I will look into replaceing this. Is this expensive? Is it a difficult part to replace?
Brian
Old 06-10-2004, 02:35 PM
TXLerxst's Avatar
I believe your delear can clear it for you at no charge -- seems a few 4.6, including mine had it, the reprogrammed the computer to correct the error and has been fine w/ the exception of two blown plugs that are currently being changed at their expense
Old 06-11-2004, 01:27 PM
temp1's Avatar
Brian
The DPFE is not difficult to replace but I think the part costs around $70 or $80...
Old 06-12-2004, 08:42 AM
BPatin's Avatar
Thanks for the help. Based on the discussions here I contacted Ford and found out my DPFE is covered by an extended waranty dure to problems. I am bringing it to the dealer today!
Brian
Quick Reply: Check engine P0405 diff. EGR problem?
