tps sensor
Old 09-23-2004, 08:48 AM
1993F150's Avatar
tps sensor
Does anyone know how to check a tps sensor on a 1993 f-150 with a 302 and a e40d trany. I think that mine is going bad and the book that I have is very vague. Any help would be greatly appreciated. Thanks
Old 09-23-2004, 12:15 PM
turbojoe's Avatar
Use a volt meter to check the voltage between the green wire of the TPS and a good ground (preferably battery NEG , but the intake will do).
The voltage should be .9 to 1.1v with the key on and the engine off...and progress slowly and smoothly to 4.5-5.5v when you open the throttle to WOT slowly and smoothly.
If the voltage isn't in range with the throttle closed, then you can adjust it...if there is a drop-out or spike in the voltage as you open the throttle...then it's bad.
Old 09-24-2004, 09:43 AM
1993F150's Avatar
Thanks for the info
Quick Reply: tps sensor
