F-250 / Super Duty / Diesel
33's or 35's for a Super Duty?
Old 12-27-1999, 02:07 PM
Joe543's Avatar
yetiman, I was thinking about centerline hellcats on my SD when it arrives. I notice you have those on your '97. How do you like them? I was planning on putting the biggest tire i could fit without a lift.
Joe
Old 12-27-1999, 03:13 PM
yetiman's Avatar
Joe,
I really like my Hellcats they have been good rims and have stayed nice and shiney.
You might want to check and make sure they make them with the super duty bolt pattern. Because the F150 and super duty bolt patterns are different.
Old 12-28-1999, 12:16 AM
yetiman's Avatar
Post 33's or 35's for a Super Duty?
I'm having a tough time deciding what size tires to put on my new super duty when I get it. I plan on putting one of the small leveling lift kits on the truck and nice wheels and tires. My question is does everyone think that 33x12.5x16.5 tires will be to small and not balance the look of the truck out right. Or should I just put 35's on the truck and be happy. I plan on getting the V10 with 4.30 rear end.
Any thoughts would be appreciated.
1997 F150, SC, SWB, 4x4, 4.6 v8, Bright Red.
Mods: Billet Grill, Exhaust, Centerline Hellcats 16x8, BFG TA 285x75x16, Clarion, Precision, JL Audio Tunes, Chip.
Old 12-28-1999, 03:33 PM
chaydu's Avatar
Smile
Yetiman,
You are going to have some clearance problems with 35's. Unless you plan on lifting it, don't plan on getting 35's under the front end.
--Chris
Old 12-29-1999, 01:03 AM
yetiman's Avatar
chris,
I plan on using either the superlift 2 inch leveling kit or the trailmaster 3 inch kit. I'm getting the V10 so won't have the extra weight of the diesel to contend with up front. I'm hoping either one of these will allow me to use 35's if I decide to go that big. I'll probably use BFG AT's in either the 33 or 35. I've had good luck with them as long as you rotate them often.
Greg.....
Old 12-29-1999, 08:13 AM
mjs's Avatar
mjs
mjs is offline
If you are planning on putting a 2" leveling kit in the truck, I would recommend 35s.
I have the 2" Superlift with 35x12.50 bfg MTs
on American Eagle rims. I was originally going to put 295s (33x10.50s) and the just looked too small.
Mike
99 F250SD SC, V10, Superchip, 2"Superlift,
35x12.50 BFG MTs
Old 12-29-1999, 10:20 AM
altec's Avatar
Lightbulb
Mike,
Do you have a digital picture of your truck with the 2" leveling kit and 35's? It seems like many are going for that set up. I pick my truck up next Monday and was thinking the 295's. I would be interested in seeing what the 35's look like.
thanks..another mike
Old 12-30-1999, 12:33 AM
chaydu's Avatar
MJS,
I'd love to see that setup also. If you have a picture, send one off to me! :-)
Yetiman,
I've also had great luck with the BFG AT's. Better luck then any other brand I have dealt with.
Chris
Old 12-30-1999, 08:26 AM
mjs's Avatar
mjs
mjs is offline
Thumbs up
Chris and Mike,
Yes, I do have pictures of my truck. I will email them to you. If anyone else wants to see the setup, let me know.
Mike
Old 12-30-1999, 08:34 AM
mjs's Avatar
mjs
mjs is offline
Lightbulb
Actually, I noticed that your email addresses are not in your profile. Email me and I will reply back with the pictures.
mike.strukel@westgroup.com
Mike
35x12.50 BFG MTs
Old 12-31-1999, 07:09 PM
4x4's Avatar
4x4
4x4 is offline
I had 33's on my truck with the 5inch lift and they were way to small. Went to the 35's and they look alot better. If you are going to go with a lift go with the 35's, if you don't lift it you should be able to run 33's with no problem. I ran 33's for 6months with no lift and really didn't have any problems.
99 F250SD Black Lariat Crew Cab 4x4, 5inch National Spring lift, 35x15.50 Swampers, 16.5x9.75 Weld Scorpios, Full Billet grill, LIne-X liner, Procomp and Rancho shocks, 40 Series Flowmaster, recalibrated speedo, superchipped,K&N filter,2 JL audio 10's behind rear seat, audio art 6channel amp
Old 01-03-2000, 10:27 AM
chaydu's Avatar
Mjs,
Send pics to chaydu@haydu.com
Thanks a Bunch! Just make sure the message is labeled truck pics or the message might get lost in my "monster" mailbox. :-)
Thanks Again.
Old 01-03-2000, 04:23 PM
Joe543's Avatar
Talking
mjs, please send me a pic too!
thanks!
[This message has been edited by Joe543 (edited 01-11-2000).]
Old 01-10-2000, 11:18 PM
XXL FORD SUV's Avatar
Hey 4X4,
What did you need to do to recalibrate your speedo? I am in the process of installing a 6" ProComp lift on my Excursion and will be installing 35x12.5x16.5 BFG AT KO's on it. For now I will have to live with the 3.73 rearend until I can find the time to drop in a 4.30. What ratio are you running?
Old 01-12-2000, 03:05 PM
4x4's Avatar
4x4
4x4 is offline
I am running 4.10's at the moment. All you have to do to get the speedo redone is to take it too your ford dealer and tell them you want it recalibrated for the 35's. Some will do it, others won't. It really is a simple process and shouldn't cost you more than 50.00. Hey e-mail me with a pic of your ride, sounds like its going to be awesome. e-mail at cfadal@ev1.net
Quick Reply: 33's or 35's for a Super Duty?
