4x4 engage problem
Old 01-03-2005, 01:28 PM
JLR's Avatar
JLR
JLR is offline
Unhappy 4x4 engage problem
Please help....I have a 1993 F-150 4x4 that will not engage in 4 wheel drive. It has the electronic button on the dash and when I push to engage all I get is a clicking noise. This noise sounds like it is coming from the glove box. I believe Ford changed the electronics in 1994 and had problems with it but I don't think this is the same problem since mine is a 1993. Could it be as simple as a bad solenoid? If so is this located on the fire wall on the passenger side?
This truck belonged to my father and I inheritied it so I do not have the owners manual. Is there a trick to engaging the 4 wheel drive?
Old 01-04-2005, 10:48 AM
Canuck PB's Avatar
Could be the solenoid on the transfer case. I had a Ranger with the same setup and that's what went bad on it.
Old 01-04-2005, 11:11 AM
JLR's Avatar
JLR
JLR is offline
Thanks for the suggestion, I will check the transfer case for a solenoid.
Old 01-15-2005, 09:52 AM
bigbronc's Avatar
Get under the truck and tap on what looks like a power window motor on the rear of the transfer case while someone else pushes the 4x4 button. The motor will get stuck from lack of use and a little tap will get it working again.
Robbie
Old 01-15-2005, 09:07 PM
Martyr Ace's Avatar
Read my note on 4 X 4 not working
Old 01-17-2005, 08:33 AM
JLR's Avatar
JLR
JLR is offline
Thanks for all the help
Thanks for the replies to my problem. I tried both of theses but alas I finally had to replace the motor on the back of the transfer case. But your suggestions allowed me to talk to the service manager with some knowledge. Great web site.
Quick Reply: 4x4 engage problem
