4x4 Vacuum Operated Front Hubs
Old 02-01-2005, 05:41 PM
Justis01's Avatar
Question 4x4 Vacuum Operated Front Hubs
I sure would appreciate someone posting an assembly scan of one of the front vacuum operated hubs on our '04 and '05 4x4's. Just curious as to how these things work and how reliable they are. I've had manual locking and mechanical auto locking (didn't particularly like the latter type) hubs on my other 4x4's.
Thanks,
Scott
Old 02-01-2005, 06:03 PM
J-150's Avatar
guaranteed to not last as long as manual hubs.
Old 02-01-2005, 06:47 PM
Jamesdc1's Avatar
One thing interesting about these hubs is that they are excercised plenty.
The vacuum from the engine "unlocks" them.
So you start your engine, they disconnect.
Stop your engine, they engauge.
-James-
Old 02-01-2005, 07:32 PM
Justis01's Avatar
That is interesting! I would hope that if one of the vacuum lines broke, the hub would be locked instead of the other way around
Thanks,
Scott
Old 02-01-2005, 08:20 PM
ZMANF150's Avatar
-James-
Are you sure its not the other way around. What's your source for this info.
Old 02-01-2005, 08:29 PM
Tbird69's Avatar
Vacuum locks the hubs, this is a failsafe. If for some reason you should lose vacuum then your not stuck with the hubs in the locked position.
My '69 T-bird has a similar thing for the headlight covers. If the vacuum fails then the covers are forced open so you can still use the lights.
Old 02-01-2005, 09:46 PM
klassic's Avatar
TBird, you got the million dollar question wrong....
Zman... here is the "source for that info".
Normal Operation
The 4x4 module energizes the IWE solenoid which applies vacuum to the integrated wheel-ends disengaging the front hubs from the front axle and driveshaft. If the solenoid is not energized, an internal spring keeps the hubs engaged. Systematically check the necessary inputs and outputs at the 4x4 module, internal components of the transfer case and shift lever, IWE components, and drive axles.
Old 02-01-2005, 10:11 PM
Tbird69's Avatar
Normal Operation
There's still vacuum involved in there somewhere though right? My head hurts!
Old 02-12-2006, 12:02 AM
desratt's Avatar
yea normally locked. then when truck is started it applys vacum then it's unlocked. I'm trying to replace my second one right now. the reason they are engaged and disengaged at the hu instead of in the differential is it saves .5mpg according to the shop manual.
Old 02-12-2006, 12:07 AM
Matt 05'FX4's Avatar
You can test this out pretty easily also. If you ever have the front of the truck off the ground or on a lift, try to spin the front wheels with the truck off. They will be locked to the driveshafts, with truck running they will not (unless in 4WD of course). This also makes me realize something else.....There is no way for someone to tow a 4x4 F150 by just lifting the rear wheels, it would have to be flatbedded.
EDIT: And if you are in 2WD and if the vacuum line were to break or solenoid to F up, the hubs would lock up.......BUT the transfer case will not be engaged so the front wheels won't be locked to the rear.
Old 02-12-2006, 12:12 AM
f150superdave's Avatar
I believe that the clutch in the transfer case is unlocked then the truck is parked. So you should be able to tow it, although the drive shaft would turn.
Old 02-12-2006, 12:45 AM
kd4crs's Avatar
Owners manual says not to tow 4WD trucks. They should be put on a flat bed to be transported.
Old 02-12-2006, 12:53 AM
Someone stealing the truck probably won't read the manual first. Actually, Ford uses sensors on the mustang anti-theft package to stop this method of theft.
freekyFX4's Avatar
Because the axles are not rotating, reducing the rotating mass.
Old 02-12-2006, 01:44 AM
bofer's Avatar
i thought if you put the transfer case in the N position, neither the front or rear shaft will turn, alowing you to tow the vehicle...atleast that was the way it was on my jeep
Quick Reply: 4x4 Vacuum Operated Front Hubs
