Upper and lower control arm torque specs?
Old 02-10-2005, 12:04 PM
SpeedJunky's Avatar
Does anybody know the torque specs for installing upper and lower control arms?
Old 02-10-2005, 05:32 PM
chucks bp's Avatar
upper c arm bolts 84-112 ft lb
lower arm nuts 121-148
lower ball joint nut 83-112
upper ball joint nut 57-76
tie rod end nut 57-76 ft lb
as per ford service manual
Old 02-10-2005, 05:36 PM
SpeedJunky's Avatar
Thank you sir!
Old 10-29-2016, 03:12 PM
Big B's FX4's Avatar
I know this is an old thread but chalk up another win for the search function!
Old 01-11-2019, 10:08 PM
Glen S. Bowen's Avatar
Smile Great, thank you very much! do you know the Axle shaft nut torque?
Great thank you very much! do you know what the axle nut torque is?
Old 01-11-2019, 10:31 PM
You mean the spindle nut on the front hubs? No specific torque, tighten it while spinning the rotor as tight as you can get it with a 3/8" drive ratchet, then stop spinning the rotor, back it off 1/4 turn, then finger tighten it. Put the retainer on with the cotter pin holes lined up and insert a new cotter pin.
Quick Reply: Upper and lower control arm torque specs?
