Wiper Control Module
Old 04-01-2005, 01:40 AM
snoplow's Avatar
On the 94 F150 there is a "wiper control module" located behind the glove box. In fact to get to it you have to remove the glove box. Does anyone know what this thing does? I'm having some funky problems with my wiper system and would just like to know what this thing does.
Old 04-01-2005, 07:37 AM
cleat's Avatar
That module controls all of your wiper and washer functions using the steering column control as an input. What problems are you having ?
Old 04-01-2005, 11:51 PM
snoplow's Avatar
When I push the washer button, I can hear it clicking behind the glove box.The wipers come on but no fluid comes out. The problem is intermittent. The pump is good, hoses are open, and nozzles are clear. I tend to think the switch is OK because it must be making contact in order to make the control module click.
Old 04-02-2005, 07:35 AM
cleat's Avatar
I know you said the module clicks but just for grins and it only takes a few minutes pop the cap off the end of the switch on the column then remove the screw and slide off the rotating part. Now clean the contacts with alcohol or contact cleaner then lube with petroleum jelly or some light grease then pop it back together and try it again. I've had to do this with every ford I've owned with this setup.
Old 04-02-2005, 03:23 PM
snoplow's Avatar
Ok, I'll give it a go. Thanks
Old 04-04-2005, 09:27 PM
tedm's Avatar
Mine did exactly the same thing... clicking near the glovebox, some of the intermittent settings wouldn't work, etc. Anyway, you need to change your MFS (turn signal switch). I did last weekend and it's perfect now. Advance has them for sixty bucks and all you need is to unscrew 3 phillips in the belly of the steering column molding and 2 T20 torx screws that hold the switch on. Unplug the two plugs and put the new one in. 30 minutes and I guarantee this will fix it. The guy at Advance will probably mention how many he sells, too.
Old 04-05-2005, 09:47 AM
cleat's Avatar
You can buy a new one but all they need is a cleanup.
Old 04-10-2005, 02:47 PM
snoplow's Avatar
I finally got around to working on my wipers ( now that it's raining again) and the cleaning of the contacts in the switch seems to have done the trick.
Thanks a bunch, guys!
Old 12-12-2011, 12:01 PM
FreeWheelin's Avatar
I also have the same problem with the 1994 Wipers. I have changed the motor, NO HELP. I changed the Switch, NO HELP. Cleaned all contacts, NO HELP. Last thing I can think of to do is replace the wiper control module. HELP !!!!!!!!!!!!!!!!!!!!
Old 12-13-2011, 09:44 PM
russo2's Avatar
Well I commend your efforts with the search function, but this thread is just a wee bit old. Start a new one.
Old 06-06-2014, 07:50 PM
smgdnd's Avatar
I took it apart
I took it apart to clean the contacts but a spring fell out and I can not figure out where it sits. I also can't figure out the proper position to put it back together. Any advice?
Old 06-12-2014, 04:33 PM
yloow5's Avatar
Russo who the heck r u to moderate crap in here
Old 06-13-2014, 01:19 AM
That post was made 3 years ago - who are YOU to complain? This isn't the first thread you've gotten cranky in.
Old 06-16-2014, 03:26 PM
yloow5's Avatar
I did the pull and cleN and mine worked fine after . Don't pay att to glc and his redirections to get an answer
Old 06-16-2014, 03:28 PM
yloow5's Avatar
No body would be cranky in here if it had answers and not MODERATIONS
Quick Reply: Wiper Control Module
