Antifreeze smell coming through AC vents
Old 05-15-2005, 05:38 AM
wetplugs's Avatar
I got 98' 4.6 Scab with 103k..I guessing it is the heater core, but have not seeing coolant loss yet. When I get on it the Antifreeze smell gets stronger.
Old 05-15-2005, 07:47 AM
Gearhead99's Avatar
Sounds like heater core for sure.
Old 05-15-2005, 07:57 AM
zapster's Avatar
if you put the defroster on and the windshield gets fogged up on the inside its the core for sure...zap!
Old 05-15-2005, 09:24 AM
ericd's Avatar
Yep - The smell is just the early warning system.
Get it swapped out before you start to experience coolant loss (on your carpet).
E...
Old 05-16-2005, 05:22 AM
wetplugs's Avatar
I just bypassed it for now...thanks
I just bypassed the heater core for now...thanks
Old 05-19-2005, 06:06 PM
rooster152's Avatar
I had this happen to me on my '97 supercab 4.6....definitely the heater core.
The dealer wanted around $1100.00 to replace the $37.00 core! 99% labor for this repair. I decided to tackle it myself with a Haynes manual at my side. Took 2 full days - you have to remove the entire dash to get at the air box that houses the heater core. A huge PIA......I paid the grand to have it done on my wifes '98 Expy when the hot/cold mix gate failed iin the airbox. I didn't need the back pain again.. I'm 6'3". I hope there are some other threads on this site, because it is a big job to take on. Good luck!
Old 05-19-2005, 09:55 PM
JMC's Avatar
JMC
JMC is offline
I have done 4 now. Takes about 8 hours if you don't want any parts left over. It is too lenghty a procedure to just type it up here. Get a good manual and follow the instructions.
JMC
Old 05-19-2005, 10:06 PM
Yankee7985's Avatar
It is a true PIA, but well worth the $1100.00 saved. Basic tools and time is all you need. Buy new quick-disconnect coupling seals also. $$$$$$$$$$$$$$$$$$$$
Old 05-22-2005, 10:25 AM
Colorado Osprey's Avatar
In general when you smell coolant inside, it is a heater core. Change it immediatly as the vapors can and will get you sick if you don't change it.
Quick Reply: Antifreeze smell coming through AC vents
