Front Seat Removal
Old 06-27-2005, 07:50 PM
greatscott's Avatar
Cool Front Seat Removal
I had a amp put under my passenger seat that has been blown. I was wondering how I could remove the seat myself so I could replace the amp? Basically, what type of tools do I need to remove the seat?
Old 06-27-2005, 08:01 PM
desparado's Avatar
Very simple. You need a T55 Torx socket and if yours is like my 01 Screw, also a T47 for the seat belt, and seat bolt on rear drivers seat. If you pull them all the way out, you need to disconnect the seatbelt alarm. I installed my amps by just propping the seat up. Have Fun!
Old 06-27-2005, 08:19 PM
greatscott's Avatar
Thanks. I'll try not to remove the seat but I don't think I will be very successful at getting to the screws holding the amp down unless I get the seat out of the way. I'll see -Thanks
Old 06-28-2005, 10:45 AM
Blonde Ambition's Avatar
I've had my seats out a couple times. Very easy.
Old 06-30-2005, 02:09 PM
greatscott's Avatar
Thanks to all....I was able to replace the amp with out removing the seat. I moved the seat forward as far as it would go and removed the back screws from the amp. They were the only thing holding the amp in.
Old 07-18-2005, 06:50 PM
henryellingsen's Avatar
T55 bit
I tried a T55 bit and it seems very loose. Is this the correct size? I don't know how much torque this fastners require, but I don't want to strip one out. When I checked I only found T50,T55,T60 increments so could experiment with a size in between T55 and T60. Any comments?
Old 11-01-2005, 04:45 PM
jamzwayne's Avatar
dzervit is right....
I did a search and answered my own question....BUT, that still brought this thread "back from the dead".
greatscott, thnx for asking for me.
Old 06-27-2020, 04:57 PM
K.Hollier's Avatar
I'm removing seats from my 2001 F150 to clean real good underneath. Last bolt on driver's seat won't budge. Any ideas???
Old 06-27-2020, 06:14 PM
Have you tried using an impact gun?
That is what I use to get truck bed bolts and seat bolts out.
Old 06-27-2020, 06:30 PM
K.Hollier's Avatar
I don't have one but my neighbor does! Good idea! Thanks ManualF150!
Quick Reply: Front Seat Removal
