Whats the quickest/cheapest way to get a couple of inches lift
Old 08-09-2005, 10:53 PM
MJ's Snake!'s Avatar
Looking to lift the front of my Expy up just a couple of inches to level it out with the back, (want to lose the rake). Whats the best way to get the front end up a couple of inches on my 2WD Expy.
Old 08-10-2005, 10:58 AM
bigtruck311's Avatar
need more info what year is it?
Old 08-10-2005, 12:12 PM
My bad, 2000 EXpy 2WD, Do they sell a coil spacer or something like that?
Old 08-10-2005, 01:41 PM
ruffn-it's Avatar
Yup, get a Daystar coil spring spacer, should run you about 50bucks, plus installation unless of course you do it yourself. Also a realignment.
This should give you 1.5in lift in the front, may not be completly level but pretty close.
Old 08-10-2005, 04:02 PM
wandell's Avatar
Yep, Daystar coil spring spacers would be the least expensive, followed by lift coils and of course lift spindles will be the most expensive.
Old 08-10-2005, 05:35 PM
THanks , should be a pretty easy install, just compress the spring, remove the shock and throw it in, may have to sepereate the a-arm and spindle but probably not.
Old 08-10-2005, 09:47 PM
Alright heres the deal,I googled Daystar and they do not make a front spacer kit for the 2WD 97-03 Expedition, only the rear. They sell them for f-150's which is wierd. Hoiw much different is the F-150 front suspension than the Expeditions?
Any other alternatives you can recomend, without lowering the back?
Old 08-10-2005, 10:11 PM
wandell's Avatar
The two suspensions are the same. The spacers for the F-150 will work.
Old 08-11-2005, 02:53 PM
ruffn-it's Avatar
I tried just compressing the springs to just throw the spacer in there but that wouldnt work. There wasnt enough room to get in there to put it in, I had to take off the top ball joint. (and in doing so you may need a realignment).
good luck
Quick Reply: Whats the quickest/cheapest way to get a couple of inches lift
