Brake Controller Wiring Diagram
Old 10-10-2005, 11:07 AM
welfare wagon's Avatar
Help! I am replacing my brake controller with a new Prodigy but I have long lost the wiring diagram that shows what wire does what coming out from under the dash to my contoller. Anyone have an one handy that can help me out? I just need wire color and what each one goes to.
Old 10-10-2005, 03:20 PM
150snowplow's Avatar
you can go on there web site and download it
Old 10-10-2005, 06:16 PM
MitchF150's Avatar
Just buy the Ford wire harness for the Prodigy and it's a plug and play deal. Costs about $10 extra..... That way you can keep your old controller as a spare just in case.....
Mitch
Old 10-12-2005, 10:36 PM
Newt's Avatar
The Ford harness is not colored the same as the Prodigy.
Ford says: White ground
Dark Blue Trailer electric brake feed from brake controller (output)
Light Green Vehicle stop lamp switch to brake controller (input)
Red fused trailer brake controller battery feed
Brown Head lamp switch to vehicle running lamps
Prodigy says: Black Positive battery
White Negatiave battery
Red cold side of stoplight switch
Blue brake output to trailer
So, double the end of the brown & tape it. It's not used. Otherwise, black to red, white to white, red to light green & blue to dark blue, Prodigy color listed first.
Old 11-04-2005, 09:21 PM
raisin's Avatar
I have that controller and the premade double ended cable and did not use the Ford supplied cable. $10.00 plugs right in.
Quick Reply: Brake Controller Wiring Diagram
