Dome light stays on in 97 F-150
Old 10-28-2005, 08:26 PM
xibbumbero's Avatar
Problem just started. At first the light would take a little longer to turn off after locking truck. Now it just stays on. I had to disconnect the battery. Anybody have this problem? If so,how did you fix it. TIA. X
Old 10-28-2005, 08:36 PM
BrianXLT's Avatar
Does the door ajar light come on in the dash?If it does you'll have to replace the sensor that's on the locking mechanism inside the door.not to difficult really.If thats the problem let me know and I'll write you a walkthrough.
Old 10-28-2005, 10:06 PM
lees99f150's Avatar
Old 10-29-2005, 05:18 PM
xibbumbero's Avatar
"Door Ajar" icon doesn't come on. I sprayed the lock mechanism w/WD-40 anyway.
Dome still stays on....sigh. I'm trying to avoid going to the dealer. I'll keep hoping for some more input. Thanks for the input so far. X
Old 10-29-2005, 08:52 PM
BrianXLT's Avatar
I'm not quit sure what it could be.If the the lights staying on and the door ajar isnt indicated then I dunno what to think of that.I'll try to do some research for ya and see what i can turn up
Old 10-30-2005, 02:07 PM
xibbumbero's Avatar
Thanx Brian. I appreciate that. I've looked meself and couldn't find anything. X
Old 10-31-2005, 07:33 PM
BrianXLT's Avatar
From the research Ive gathered,the only other thing that could be keeping the dome light on without the door ajar sensor being on is the GEM.It controls several different functions such as the dome light,window wipers,window washers,door chime,and various other functions.Even though they sell the part Ford will probably neglect to tell you that it needs to be programmed from them for that specific year make and model with all the features you have and dont have.I think the parts roughly 130 from what Ive heard and I dont know how much Ford would charge to replace it and reprogram it.I don't know if its the case or not but the finger does point to it and the main reason being the door ajar isnt on.Good Luck to You
Old 11-01-2005, 01:56 PM
xibbumbero's Avatar
Brian,Thank you very much for your help. X
Old 11-26-2005, 10:16 AM
dgm999's Avatar
I have this problem too!
Look through the other threads...I saw this reported there and I have this problem on my 97 F150 as well. They say to spray the door latches with WD40..which I will try. I have lived with this problem for a long time (took the interior bulb out)!!!
Old 12-01-2005, 11:58 PM
Ben05F150's Avatar
yes wd-40 will work. spray ALOT down the door latch it will run down and lube the unit and make the light shut off. My 98 Expedition did the same thing and I heard about this trick and it worked like a charm.
good luck
Old 12-02-2005, 06:49 PM
6T6CPE's Avatar
If you decide to work on your door locks the door panels are a snap to get off. They don't pull off but lift off. Take off indoor handles and pop the two trim pieces off on each side of the panel at the window. Pop out the 2 plastic screws and the door panel lifts straight up. Power windows and doorlocks will have to have the harness disconnected which pops right off also.
Old 12-10-2005, 04:16 AM
vegasman's Avatar
After spraying the lock mechanism alot, open and close the door fast about 20 times and this will shake the sensor loose again. happens all the time.
Old 12-10-2005, 09:59 PM
newyorkboy's Avatar
Does anyone have a picture of the door latch?I try this but it did not work.I don't know much about cars and trucks so I could of spray it in the wrong place.If you could help I would appreciate it I now it is hard to help someone that does not know anything about trucks so thanks.One more thing I have a expedtion and I am looking to buy a F150.I would like to look things up on the F150 so what forum do I go to.They don't have just a F150 forum it is king ranch or supercrew is there a difference in the 3?
Old 12-11-2005, 02:25 PM
lees99f150's Avatar
check the link i posted above.
Old 12-17-2005, 03:12 PM
Erikpn's Avatar
Excellent Thread, I finally had this fixed, my passanger side door was giving that problem. Thanks.
Quick Reply: Dome light stays on in 97 F-150
