inertia switch
Old 11-09-2005, 03:28 PM
n8sf150's Avatar
inertia switch
my fuel pump wont kick on all the time. someone suggested the inertia switch does anyone know where that is?
Old 11-09-2005, 03:44 PM
dye7barrel's Avatar
If we are on the same page, the switch is located on the passengers side kick pannel. Pop off the pannel and there is a little red button which should be a winner.
Old 11-09-2005, 05:03 PM
lees99f150's Avatar
For a 97 and up but, on a 88 its on the firewall to the left on the brake pedal.
Old 11-09-2005, 05:09 PM
lees99f150's Avatar
When it acts up check the voltage at the pump. i believe on a 88 the pump is mounted to the frame on the inside on the left side. also check for corrosion on it. the relay may also be going bad.
Quick Reply: inertia switch
