Fuel Pump Reset Button???
Old 11-29-2005, 10:49 AM
I was looking in the manual and they mention that at times you may need to hit the reset button to reactivate the electric fuel pump. The said it is behind the passenger side kick panel in front of the fuse box. I looked and could not identify anything that looked like a reset button. I even removed the cover for the fuse box. Can anyone help me identify the reset button. Just wanted to be prepared in case I ever need to use it.
Old 11-29-2005, 12:25 PM
Three B's Avatar
If im not mistaking I believe it is under the glove ocmpartment. Not right under neath it but keep following down to where the plastic stops! Then there is a opening it should be in there! How i know is i kicked this off before by accident! JUst sit in it put your feet as far as they can go, and thats where the switch is!
Old 11-29-2005, 12:27 PM
Thanks, i will look there. That certainly is not where the manual says it is.
Old 11-29-2005, 12:39 PM
J-150's Avatar
you should be able to reach it without removing any panels.
Old 11-29-2005, 12:41 PM
Ok. My manual says to remove the kick panel and it even has a gas pump stamped on it. Sounds as if they moved it.
Old 11-29-2005, 01:25 PM
valley818's Avatar
Here ya go. 5th picture down, courtesy of myst... Link
Old 11-29-2005, 01:35 PM
KSpencer's Avatar
Beat me to it.
Old 11-29-2005, 02:00 PM
Thanks so much, I just went to the parking lot to check it out. I will need to look when I have a flashlight, will check it when I get home. Thanks again.
Old 11-29-2005, 02:06 PM
ford2004F150's Avatar
Here is the pic off myst site... you guys beat me to it...
Old 11-29-2005, 02:08 PM
I can't wait to check this out, because if I remember correctly, I have the black square that looks like it is holding that switch, but nothing in it.
Old 11-30-2005, 09:26 AM
Ok, with the help of the pic, I found it last night. You have to stand on your head and get your eyes past the fuse box. It is close to the inner fender, mounted on the back edge of the fuse box. If I ever have to reset this button, I am glad I found it before the emergency! Thanks for your help.
Quick Reply: Fuel Pump Reset Button???
