How to test COPs (coil on plugs), '01 F150 w/155K miles misfire??
Old 01-30-2006, 07:03 PM
mueller's Avatar
Waiting for AAA as I write this
Started truck up at lunch, noticed a slight "hiccup", turned off truck, started it back up, idled fine. A few hours later left to drive home, ran fine for 10 minutes, now it's worse.
Shake is worse with load, from what I've been reading it sounds like the COPs give up at about this time frame/mileage???
Any way to test them with a voltmeter or scope?
thanks
Old 01-30-2006, 07:14 PM
trikepilot's Avatar
Mueller, I was always able to find the bad one by comparing readings on an ohm meter. I don't know what value I got but, I replaced the one with a value that was way off compared to the others. For me it was easier to remove them and test them on a bech. It fixed it for me. Autozone now stocks them, if you shop aroung you can get a good deal. If I remember I had Autozone match checkers price of $35-40.
Good luck!
Scott
Old 01-30-2006, 07:46 PM
Quintin's Avatar
First, get the codes pulled to see which one is flaking out. The easiest way without being able to do a power balance or coil stress test would be to simply walk that bad coil around to a cylinder that isn't misfiring to see if the misfire follows that coil. Just because an ignition coil checks okay resistance wise doesn't mean that it'll hold up under load.
Old 01-31-2006, 12:44 PM
brownfordgt's Avatar
What if you don't get a code? I don't have that bad of a running problem, but at times a rought idle when cold, or it might take a couple cranks to fire up(happens about 3 out 10 times) I had changed plugs, boots, IAC, cleaned the TB. No codes, changed programs with my programer, changed fuel filters. I did notice that the blades on a couple of the coils had a slight greenish glaze.
Rob
2000 5.4L Exp
Old 02-02-2006, 06:33 PM
hpipe's Avatar
Im getting ready to check the COP's tonight...Autozone said my code was P0355 Ignition Coil Primary circuit malfunction which really doesn't tell me a whole lot....any suggestions on which one...or if it is a COP problem at all?
Thanks,
-h
Old 02-02-2006, 08:20 PM
Redfisher's Avatar
Does anyone know if there is a TSB on the COP's and where to find a free copy?
I have an 01 SCrew 5.4 and had one go bad at about 20k - dealer misdiagnosed first and got it right the second time. Recently at 78k I had another go bad while on a trip - limped into a dealer who took me for $400 to replace another COP. Now I have the early symptoms of another going bad.
Is this a horrible design? Should Ford replace for free? Just upset and wondering...
I really want to get +150k out of this truck, but don't really have the time to mess with this issue every few weeks!
Are they easy to replace once the culprit is identified?
Thanks!
Old 02-05-2006, 01:37 PM
lmiller65's Avatar
Smile yes they are
I found they are very easy to replace. but I did find that number 8 and number 7 are the hardest. Number 4 is difficult but easier then 8 and 7. The others are extermly easy.
Old 02-05-2006, 09:55 PM
hpipe's Avatar
You are right...I gave up on 7 and 8...4 is bearable...Did you have to take off the fuel rails for 7 and 8?????
Oh...all of my coils look the same except for two of them...those two have a green motorcraft sticker on them...the rest are black. I am wondering which are the replacements and which could be factory?????
By the way, I switched around the 5 and 6 to see if it would throw a different error and no...it did not...so I now think that the coils are not the problem...and they checked out ok on the OHM test...
I'm stuck now and looking for a good place to take the truck...in Ohio...
-h
Old 02-05-2006, 10:00 PM
Quintin's Avatar
The ones with the green Motorcraft stickers are originals. Replacements have a black top with the part number written in white lettering on them.
Old 02-05-2006, 10:36 PM
hpipe's Avatar
Thanks Quintin...I owe you one!
Hmmm...the original codes were for the two cylinders with the green stickers on them....perhaps I should swap those for new ones even though the ohm test checked out???....then take it to a shop if that does not cure it.................
-h
Old 02-05-2006, 10:54 PM
Quintin's Avatar
That's what I'd do. Remember, just 'cause they ohm out okay, doesn't mean that they won't break down under load.
Old 02-05-2006, 11:00 PM
hpipe's Avatar
Thanks again...I did not know that... I'll go ahead and get two of them tomorrow...
-H
Old 02-05-2006, 11:28 PM
hdfordfan's Avatar
If you purchase a Haynes book it will tell you how to test the COP with an ohm meter. I noticed with my old truck 2000 F-150 w/ 5.4 it did not like anything but the motorcraft plugs that came w/ it originally. I also know O'Reilly's has a COP by borg-warner that carries a lifetime warr. Good luck
Quick Reply: How to test COPs (coil on plugs), '01 F150 w/155K miles misfire??
