PCM location
Old 02-02-2006, 06:50 PM
HankMonster's Avatar
PCM location
Where is the PCM located on a 05 F150 Screw?
Old 02-02-2006, 06:55 PM
C-17 Pilot's Avatar
It's located on the passenger side firewall in the engine compartment.
Old 02-02-2006, 08:23 PM
Rockpick's Avatar
Moderator &
Look to the back left corner of the pic -- see the thing with the three plugs going into it? That's the PCM.
RP
Old 02-03-2006, 05:33 PM
Superchips_Distributor's Avatar
Former Sponsor
Hi HankMonster,
Just as Rock Pick kindly shows in his photograph, if you look at the top left corner of that picture - it's the device with the three wiring harness connections leading into it.
Just pop the hood, look at the top of the firewall a bit left of center, & you can't miss it - it's the module with the 3 wiring harness connectors plugging into it.
And that's a might clean underhood Rock Pick has there, by the way.
Quick Reply: PCM location
