Removing 94 door panel
Old 03-18-2006, 09:53 PM
antiqman61's Avatar
How do I remove the door panel on my 94 so I can work on the window mechanism?
Old 03-19-2006, 02:59 AM
Jrpotts01's Avatar
Thumbs up
Hello,
Should have plastic clips holding it to the door. Pry it off with a screw driver. Lift up on it to get it over the door handle. Hope this helps.
Old 03-19-2006, 11:02 AM
adrianspeeder's Avatar
Howdy and welcome!
Manual or electric windows/locks?
Adrianspeeder
Old 03-19-2006, 06:32 PM
ShorgasmIII's Avatar
with power locks/windows you have to remove a few screws.
1) remove the one holding the window/lock panel and slide out. disconnect the power.
2) remove the one that is in the door hand-hold
3) remove the one in the upper corner of the panel (near where the mirrors are)
4) along the bottom of the panel, there are 3 or 4 screws attaching it. remove.
now take a screw driver or panel puller and pry the sides/ bottom off the door.
basically, you just lift it out and up, around the handle and lock. reverse to put back on
Quick Reply: Removing 94 door panel
