97 F150 XLT 4x4 Wheel & Tyre Size advice
Old 04-12-2006, 01:28 PM
Edaacint's Avatar
Hi, I've just discovered the site, and I'm from the UK. I've bought a 97 F150 XLT 4x4 (regular cab, long bed) and it is fitted with alloy wheels with 255/70 R16 tyres. Can anyone let me know what the wheel and tyre size is that it should have had when it was new and also what are the biggest tyres I could fit on these wheels without having to lift the body. Basically I'm trying to reduce the gap between the tyre and body because at the moment I think it looks too big. Also would a off road tyre look bigger than a road tyre of the same size. Thanks very much for any help you can give me.
Old 04-12-2006, 01:42 PM
MitchF150's Avatar
The stock wheel size is 16x7 for any of the 16" factory wheels. The 17" ones are 7.5" wide.
Actually, the 255/70/16 IS the factory size for the 16" wheel.
You can easily go to a 265/75/16 (~31" tall) and the max would be a 285/75/16 (~33" tall) without any modification to the suspension.
Now, even going to the 265 will put your speedo/odo off by some 5%. When I put on the 265's I had to get a new VSS gear with one less tooth to get the speedo/odo (and the trucks shifting characteristics) back in order.
This is an older shot, but this is what the 265/75/16's look like....
Mitch
Old 04-12-2006, 04:57 PM
wandell's Avatar
If you are keeping the stock wheels, I'd go with a 285/75-16 (33x11.50).
Quick Reply: 97 F150 XLT 4x4 Wheel & Tyre Size advice
