Propane Conversion
Old 04-13-2006, 11:45 PM
expy03's Avatar
At work, we have 40-50 factory equipped f-150 bi-fuel trucks (propane/gas). They are 2001-2003 7700 5.4 auto. We have found the trucks to be very troublesome. In the 100k miles total I have put on two trucks, I ran three tanks of propane, because I was afraid the truck would breakdown and would end up at the dealer for a long period of time. Our mechanics hate the system and tell me unofficially they are trying to get enough of the systems to fail to justify taking them off the trucks. Other than the bi-fuel, I love driving these 7700's.
What would normally be the problem when they broke down? Did it cause problems with the vehicle, or was it the propane system that had problems?
Old 04-14-2006, 10:54 AM
fairlaner's Avatar
To run the truck on propane, you have to shut off the motor, switch to propane and then restart the motor. What would happen is you would shut off the truck, switch to propane, and the truck would not start. You would then switch back to gas and the truck still would not start. At this point, your truck was put on a lowbed and hauled to a dealer in Sacramento. You might see your truck again in a month! Our mechanics told me a valve under the hood was often the culprit, to the tune of over $2500! These valves would also leak propane under the hood...not a good situation. In all fairness to Ford, the little bit I ran the propane system the truck ran great, although you had to crank the motor approx. 3 times as long to start!
Old 04-17-2006, 12:33 PM
keltic's Avatar
Lightbulb
Originally Posted by qrb912
I have a 2001 F-150 with a 4.6 liter motor. I have been trying to fond some information regarding a conversion kit that will let me run porpane/natural gas and gasoline. Dose anyone have any information about the pros and cons of a conversion like this. Also, I would like to find out if anyone knows where to get sytem like this.
Hi
I have an Ford F-150 1998 5.4L which i got LPG converted last year.
In Norway it is very common to convert US Trucks to LPG because of our high gasoline prices.
1.9 USD per liter of gasoline 95 octane, and less than 0.8USD per liter of propane
The system i have in my truck is from BRC (italian) and hooks up to the engine computer. it has propane injectors which are drilled in to the intake manifold (the usage increases with about 3 percent compared to gasoline).
If anybody is interested in pictures/more info etc. just let me know and i'll post them here.
YS
Kjartan
Old 04-18-2006, 12:46 PM
chester8420's Avatar
Originally Posted by keltic
Hi
YS
Kjartan
That's cool. If you get a chance, take a picture and put it here. I'd like to see it.
Old 04-18-2006, 03:15 PM
PONY_DRIVER's Avatar
Post some pics, please.
Old 04-18-2006, 04:55 PM
keltic's Avatar
Ok here goes
Sorry about the crappy image quality (Qtek Mobile phone).
Left side injectors
Vaporizer in left, filter in front
LPG System computer in top right
Right side injectors
Old 04-18-2006, 04:56 PM
keltic's Avatar
The switch to toggle between gasoline and propane
Picture of the tank
Picture of the tank
Picture of the tank
Old 04-18-2006, 04:57 PM
keltic's Avatar
The front of my truck (2006 model ford emblem)
The company in poland who installed my system
Old 04-20-2006, 09:58 AM
That's COOL!!!
Old 04-21-2006, 12:57 AM
Sweet
Ya, that is super cool.
Old 04-21-2006, 01:18 AM
cyclone vampire's Avatar
question, I was under the asumption propane could not work with out cast iron head's and that propane needed a higer compression ratio, on the 98 F-150 owned by Keltic, are the propane injecters mecanical or electronic and how would the coumputer adjust air flow/timming and do you need 02 sensors?
Old 04-21-2006, 06:34 AM
keltic's Avatar
BTW: Got some product pictures
System scematics
The computer
The injectors
Old 04-21-2006, 06:42 AM
keltic's Avatar
I think the injectors are electronic.
The computer taps in to the original system, it also shuts off gasoline while the propane injectors take over (while the engine is runnning with a touch of a button)
The truck always starts on gasoline, and when the engine reaches a certain temperature it turns over to propane. The truck may also be forced over to gasoline, but cannot be forced to start on propane.
Old 04-21-2006, 08:45 AM
biff150's Avatar
keltic
what does a system like that cost? Is it available in the US? Thanks for the post, very interesting option.
Old 04-21-2006, 11:13 AM
keltic's Avatar
Originally Posted by biff150
keltic
I have no idea if its avalible in the US, check out: http://www.brc.it/default_en.html
The system cost me 19.300 NOK (aprox 3.000USD) (+ 4.500NOK in traveling cost to Poland from Norway, where i also got cheap vodka and beer)
When i got a price quoute here in Norway they said about 50.000NOK (aprox 7.812USD)
(6,40NOK = 1USD)
I drive about 20.000 US miles a year and use 7500 USD a year in gasoline, with this system i am down to roughly 3300 USD a year. And since ive had the system for a little over a year now, this money has earned it self.
(all theese number are rough estimates)
Note, since this is a LPG injection system the usage only increases with about 3 percent, compared to older system which have a 20 - 30 percent increase in usage, and drop in performance.
I dont tow a lot except for my one ton boat which i drag around 2 times a year, then my usage obviously increases but on this i have no clue if the truck uses a lot more propane than gasoline.
My boat: Ibiza 19" Sport with 175 HP
Quick Reply: Propane Conversion
