What size socket for O2 sensors
Old 04-17-2006, 01:08 AM
97f150f/s's Avatar
What size is the o2 sensors on the 97-04 f150s? I want to change mine tomorrow but not sure if it have the socket or wrench for it.
Old 04-17-2006, 01:24 AM
Johngs's Avatar
It helps if you go to AutoZone or some store like that and rent the O2 sensor sockets...they have a slot in the side so the socket slides over the cables.
But in any case, I believe its a 7/8" or 13/16"...I forget which one.
Old 04-17-2006, 02:23 AM
PKRWUD's Avatar
It's 7/8".
Old 04-17-2006, 07:01 AM
greg hazlett's Avatar
Originally Posted by PKRWUD
It's 7/8".
+1.
Old 04-17-2006, 10:18 AM
JMC's Avatar
JMC
JMC is offline
The nut on the O2 Sensor is a 22mm.
JMC
Old 04-17-2006, 10:28 AM
racerf150-2's Avatar
i found the easiest way when changing mine was a 22mm stubby.
Old 04-17-2006, 10:44 AM
Plandry's Avatar
7/8 = .875 in = 22.2 mm, 22 mm may be the right size but 7/8 has worked fine for me in the past
Old 04-17-2006, 11:37 AM
JMC's Avatar
JMC
JMC is offline
Nine times out of ten a standard size wrench/socket will fit on a metric bolt and vice versa. It is that 10th time that gets you. I must confess that I have been in situations that have seen me use a standard tool on a metric fastener but I leave that up to the individual to decide. That is why I strive to provide the most accurate information that I can.
JMC
Old 04-17-2006, 11:41 AM
rmeidlinger's Avatar
Make the O2 Replacement Easy
make life easy
remove the inner fender wells- about 6 screws and 5 minutes
disconnect the wire harness
use a 22mm or 7/8 box
no need for a special tool plus disconnecting the harness becomes much easier
Old 04-18-2006, 12:44 PM
chester8420's Avatar
I just used a regular sized 7/8 inch wrench. It was easy. The only thing I removed was the transmission dipstick tube. 1 bolt.
Old 04-18-2006, 02:38 PM
SSCULLY's Avatar
For future, I got an O2 sensor flex head wrench, that is like a 2 sided open end 22mm wrench.
Worked great, but now that I read the remove the inner fender wall trick, I might not need it any more.
Old 04-18-2006, 02:46 PM
fender well trick works for the starter too
Old 04-18-2006, 03:03 PM
JMC's Avatar
JMC
JMC is offline
Not if you have headers.
JMC
Old 04-18-2006, 03:24 PM
The hard part for me was getting the plastic clip loose. The sensors were easy to unscrew with a regular wrench.
Old 04-18-2006, 03:32 PM
JMC
somedays life ain't fair
engineering is said to be a science of compromises
go fast- give up mileage/get good mileage -go slow
have headers and go fast(maybe)/ starter removal goes slow
Quick Reply: What size socket for O2 sensors
