Tranny Fluid for 97 F150 4.6 V8
Old 04-19-2006, 02:08 AM
Scrappy T's Avatar
Purchased used F150. No owners manual. What tranny fluid is recommended. Number codes on dip stick are F65P7A020-EA. Please help. Thanks.
Old 04-19-2006, 09:18 AM
projectSHO89's Avatar
Download owner's manual from www.fleet.ford.com and look it up
Steve
Old 04-19-2006, 11:34 AM
adrianspeeder's Avatar
Gonna have to look for your trans code on the door jam sticker and then look here.
https://www.f150online.com/forums/sh...d.php?t=211867
I'm in a generous mood however and say that if you have a code of E (the E4OD trans) use Mercon/DexronIII, and if you have the more common for your truck code U (the 4R70w) use Mercon V.
Adrianspeeder
Old 04-19-2006, 09:02 PM
Scrappy T's Avatar
Thanks for the help.
Old 04-20-2006, 08:49 AM
So which tranny do you have?
Adrianspeeder
Old 04-20-2006, 08:57 AM
casey_1's Avatar
I'll give 100:1 odds it's a 4R70W, since there never was a 4.6L E4OD combo.
Old 04-20-2006, 12:14 PM
I know we all know that, but all I need is to find one for the tranny info page...
Adrianspeeder
Old 04-20-2006, 01:17 PM
casey_1's Avatar
Keep looking....
Old 04-20-2006, 08:00 PM
temp1's Avatar
Yep, probably a AODE transmission...
Old 04-20-2006, 10:00 PM
casey_1's Avatar
Nope, not AODE. The last AODE was made in 1995. After that they were all 4r70Ws.
Old 04-21-2006, 08:22 PM
fordninja's Avatar
There was a 4.6 e4od combo, but it was in a light duty f-250.
Old 04-21-2006, 10:33 PM
temp1's Avatar
so... whats the difference between an AODE and a 4r70W besides the name designation?
Maybe I should have said "AOD-EW".
QUOTE:
"AOD-EW
A special version of the AODE was released in 1993 with the Lincoln Mark VIII. This AOD-EW included wider-spaced gears for relaxed high-speed cruising and stronger internals. This transmission was later renamed 4R70W."
http://en.wikipedia.org/wiki/Ford_AOD_transmission
Old 04-22-2006, 12:00 AM
MIGHTYFUR1's Avatar
i once owned a 1997 f150 with that engine. The trans. came with the mercon III but you can change over to the mercon v since it is more synthetic and better for the trans. but do not mix the 2 together. i would change out the filter and flush the whole thing and start from scratch. you will notive a big difference when you flush the trans. you are going to have to change the fluid atleast every 25000 miles if you want to keep your trans. working in the future. I know have a 1997 f250 light duty with the e4od trans sometimes called the 4r100. much better than the other.
Old 04-22-2006, 09:24 AM
The E40D is not the same as the 4R100.
The 4R100 replaced the E40D.
Ask your transmission rebuilder....
Steve
Quick Reply: Tranny Fluid for 97 F150 4.6 V8
