2003 5.4 Knock Sensor
Old 05-02-2006, 12:42 PM
Fanuc's Avatar
Question 2003 5.4 Knock Sensor
Where is the Knock Sensor on a 2003 5.4 and is there just one?
Old 05-09-2006, 11:47 AM
Fanuc's Avatar
Anybody?
Old 05-10-2006, 10:50 AM
phillyford99's Avatar
Talking
The knock sensor is located on the drivers side front of the intake. You will see the wire going in at the thermostat area, Easy to locate.
Old 05-10-2006, 03:47 PM
Fanuc's Avatar
Thanks, I will check it out to night
Old 05-10-2006, 04:33 PM
01Roush's Avatar
What year did they move it? My 2001 has it mounted under the intake manifold in the middle of the block valley.
Old 05-10-2006, 05:12 PM
Neal's Avatar
HI!... The knock sensor on all the modular engines is located in the middle of the "LIFTER" valley, directly under the intake manifold. Due to FORD using a really long bolt to hold the knock sensor in place, you will have to remove the entire intake manifold to get it out. The bolt will back out and it's head will hit the bottom of the intake manifols plenum before totally coming out. Once you get it out install a stud and nut. This will make it 10 times easier to change next time. Do not use a shorter bolt due to the K/S uses the long bolt to help hear knock in the block.
This is what the K/S looks like :
Here it is installed in the block :
Old 05-10-2006, 09:36 PM
Fanuc's Avatar
hahaha well not an easy fix .... thatks all
Quick Reply: 2003 5.4 Knock Sensor
