Last edit by: IB Advertising
How you got codes PO171+PO174? Find out what others did to solve the problem.
Here’s a helpful hint to solve your issue Click Here
Read full discussion for further information
Check Engine Codes: PO171+PO174 System Bank? What do they mean?
#91
#92
#97
http://www.fordscorpio.co.uk/fuelmonitor.htm
#98
well my light can back on and i was right my MAF was good to began with and its actually a fuel pressure problem....the pump is working fine, it losing pressure at the engine, so they have my truck for a few days while they test every point they can in the fuel line system, and once i know exactly where it was ill post with details. and the part that messed up the ford master tech was my truck is still running like a champ, and my question to him was how come he didnt test the fuel pressure the 1st time i took it in.
#99
f 150 po171, po174 4.2 L
I was reading all your post and found my problem, 4.2 L engine, I sprayed two cans of brake cleaner trying to find the vacumm leak, I knew this was the problem but no luck, then you all came into my life, the tube that inserts into the right side valve cover (behind the coil packs) was not in the valve cover, I could hear a hissing noise up by the throttle body, well they put the PCV valve attached to the throttle body and run a plastic tube to the vavle cover, reinstalled and no check engine light,
#101
#102
I believe in your case I would somehow check fuel flow with would cause it to run rough. Good luck
#103
0171 and 0174
Got these codes, read all 7 pages of this forum trying to get more insight into my particulars. its a 2000 f150 2wd 5.4 base model.
I have replaced the cats, o2s, plugs, COPs, cleaned injectors, cleaned MAFS, visually inspected the "elbow" and all vaccuum lines, intake gasket to the best of my abilities. Even did the starting fluid trick around the intake and cant come up with anything. Dont hear hissing, brakes are still firm, and seems to run fine. The CEL just came on yesterday first time for these 2 codes. I replaced the COPs last week im wondering if I bumped something? I have been getting about 265 miles per tank as of lately and it was about 325not long ago. I just went over everything again and I found one thing out of place, a small rigid line that was out from where it plugged into, I am including a picture with it circled in red also circled in blue the piece i believe is the ill fated "elbow" hoping someone can confirm I have identified it correctly. I am forced to drive this truck with these problems so the sooner I can catch whats wrong the better I will feel about this lol. Mileage is 202,xxx
http://i167.photobucket.com/albums/u...enginehose.jpg
