97 F-150 GEM location?
Old 09-20-2006, 03:57 PM
seacapy's Avatar
Need to troubleshoot and possibly change the thing, can someone tell me exactly where it is and what I have to do to get to it?
Al
Old 09-20-2006, 04:20 PM
JMC's Avatar
JMC
JMC is offline
It is attached to the Central Junction Box inside the cab. Remove the bolts holding the CJB and pul it down. On the other side of it is the GEM.
JMC
Old 09-20-2006, 04:24 PM
seacapy's Avatar
is that the fuse/relay panel under the drivers dash?
Thanks for the reply
Old 09-20-2006, 04:27 PM
JMC's Avatar
JMC
JMC is offline
Ok, that was a cheap reply.... Disconnect the Battery. Remove the fuse panel cover. Remove the lower instrument panel steering column cover. That is the panel with the pocket inder the steering column. Remove the bulkhead electrical connectors from the fuse panel. Remove the 2 nuts and 2 bolts hoding the fuse panel in place. Remove the GEm connectors. Remove the GEM screws and remove the GEM.
JMC
Old 09-20-2006, 04:29 PM
seacapy's Avatar
Thank you very much!
Quick Reply: 97 F-150 GEM location?
