Auto 4x4 disengage?
Old 10-09-2006, 09:17 PM
Unlawful's Avatar
Registered User
Auto 4x4 disengage?
I just bought a 01 Explorer with auto 4x4, don't think I like not having normal 2wd , anyway to disengage the automatic 4wd? I haven't looked yet but there must be a solenoid of some sort to engage the 4wd when the truck spins so there must be a way to disconnect it, anyone?
Old 11-01-2006, 07:35 PM
Johnny Venomous's Avatar
I've got a 99 expedition, and I would also like to convert it to a 2wd instead of awd. I do not like how the transfer case engages.
Old 11-05-2006, 11:52 PM
awdrocks's Avatar
go here you will find your answer:
http://www.explorerforum.com/
Old 11-06-2006, 12:04 AM
ws6_guyscrew's Avatar
in mine it was full stop, shift to neutral, switch to 4x4 lo, 4x4 high, or 2wd, back in drive & go
Old 11-06-2006, 07:35 AM
GIJoeCam's Avatar
The Control Trac system in the 97-01 Explorers and the 99/00-02 Expeditions didn't have a choice for 2wd.
Run a search on the Explorer Forums (www.4x4central.com) for the 'Comprehensive Brown Wire Mod' and all your questions will be answered.
The system is virtually identical for the Expeditions. If you have 4auto, 4high, and 4low on the switch on the dash, the same exact mod will work for you too. The wiring and operation is identical.
-Joe
Quick Reply: Auto 4x4 disengage?
