97 F150 4x4 will not work?
Old 10-18-2006, 09:17 PM
TomRowan's Avatar
I read thru the posts and didn't see anything that applied, so here's my problem.
*First Problem*
1997 F-150 automatic, I hit the switch on the dash to go into 4 wheel drive and the lights come on ( both low and high ) but no 4x4. It sounds like something under the truck engages, but nothing further~!
*Follow up question*
Anyway when this happened, I couldn't pull a boat out of a lake and got stuck in water halfway up the bed ( the rear sank in the muck ). I left the truck running for about an hour after I got towed out. I hope that took care of water in the exhaust, I'm having the rear brakes checked tomorrow, anything else I should watch out for?
Thanks in advance,
TomRowan(AT)Comcast.Net
Old 10-18-2006, 10:30 PM
GrnXnham's Avatar
You'll need to replace the rear differential fluid if the axle was under water.
Old 10-23-2006, 12:06 AM
RpSS4844's Avatar
I had a similair problem in my 99 with the 4x4. Check the vaccum motor and the solenoid under the truck. My problem was the solenoid (may not be propername) It is located near the front differential behind a protective cover, and has two vaccum lines running to it. What you hear I am pretty shure is the transfer case locking in and the front drive shaft is probably turning, but the front axels arent being engaged to the differential....so no 4x4. Try this, if it doesnt work check the vaccum motor located under the hood on the passenger side firewall. Alos inspect the vaccum lines closely, if they are dry rotted and leaking it could very well be the problem. Good luck!!
Old 10-23-2006, 08:30 PM
JTDEERE's Avatar
I think it's called some kind of actuater.
Just my half a cent... If that.
Old 11-05-2006, 12:00 PM
NoBow's Avatar
97 4x4 wont engauge
well I had a problem like yours, every thing seem to check out just fine.. vacuum lines syliniods etc.. what my problem on my 97 f150 4x4 was the ground switch on the transmission.. i believe it was 40 dollars at the dealer... an easy fix... there is a steel ball bearing on the inside of the switch that when 4x4 it engauged it gounds out the system activating the 4x4.. commonly goes bad... check it out.. you might be surprised... I was
Old 11-07-2006, 04:19 PM
TomRowan's Avatar
97 4x4
Will do, thanks to all!
Old 11-07-2006, 08:01 PM
JTDEERE's Avatar
I think this is what you guys are talking about. This ended up being my problem too.
Oil switch / four wheel drive indicator switch (has two names)
Let us know if works.
Old 11-07-2006, 10:03 PM
jjmIII's Avatar
https://www.f150online.com/forums/sh...d.php?t=192971
My first question after joining here...
Old 11-07-2006, 11:12 PM
Camarothatcould's Avatar
I'm having trouble with my 4x4 too. Sometimes it will go into 4x4 but when I go to turn it off it stays on. I have to d/c the battery cable to reset it. At work today we put the WDS on it and said it was probably the "gen mod". $119. But I'll have someone else look at it
Old 11-08-2006, 03:28 PM
JTDEERE's Avatar
Ah yes. At least they're simple fixes.
Originally Posted by jjmIII
Old 11-15-2006, 08:39 AM
NoBow's Avatar
oil pressure switch
ya, thats the one... and not hard to get to either. 4x4 has worked great ever since I changed it.
Old 11-16-2006, 06:47 AM
bullseye670's Avatar
Perhaps I'm mistaken but doesn't that switch tell the truck that its in 4x4 mode? If that goes bad I don't think the 4x4 light would come on.
Old 11-16-2006, 04:16 PM
JTDEERE's Avatar
Correctamundo. My vacuum was all ok, but I didnt have any 4x4 or low range light on. I replaced that switch and everything works again.
Old 11-19-2006, 11:04 AM
jvangel's Avatar
Where is that switched located ?
Old 11-19-2006, 11:16 AM
JTDEERE's Avatar
Its on the front of the transfer case. About where the cab meets the bed maybe, but underneath. There is a plug going to it.
Quick Reply: 97 F150 4x4 will not work?
