Mercon V used in 4R100
Old 10-31-2006, 11:31 AM
nick-h's Avatar
I made a big mistake. I flushed the tranny fluid and used Mercon V. I know I have a 4R100. How this happend is my oversight. I did two other vehicles that day and I thought I use the right stuff. One '92 F150 and a '99 merc sable. Question is. Will this damage the tranny? If so, how?
Old 10-31-2006, 12:02 PM
projectSHO89's Avatar
Mercon V now is the correct fluid for your transmissions in ALL of those vehicles..
The fluid spec was changed via TSB this summer as Ford is discontinuing the licensing of the manufacturing of Mercon.
Just go drive 'em and don't worry about it.
Steve
Old 10-31-2006, 12:12 PM
adrianspeeder's Avatar
The ford powertrain engineer I talked to awhile back said to me that the E4OD/4R100 was designed to have no friction modifiers in the fluid. I don't know what to make of this random spec change other than I'm stockin up on Motorcraft Mercon.
Adrianspeeder
Old 10-31-2006, 02:07 PM
dirtyd0g's Avatar
MerconV is not the correct fluid for a 4r100,e4od or 5r110 transmission. Those require mercon fluid. As far as i know all other ford transmissions are rated to use the merconV now.
Alan
Old 10-31-2006, 08:07 PM
With all due respect, the TSB is quite specific.
It states that all applications that previously required Mercon may now be serviced with Mercon V.
If you're still concerned about Mercon vs Mercon V, just use Dexron III after the inventory of Mercon is depleted.
Steve
Old 10-31-2006, 09:29 PM
raisin's Avatar
I was on the website (Factory Teck) for the heavy duty rebuilt 4R100 and it said not to use Mercon V in the 4R100. I bought a case of Mercon and put it next to my bottle of R12 freon for my 89' Bronco. One week V is bad for 4R100 and next week its OK, what's that about. Like I feel I can trust Ford to look out for my welfare once I hit 100K plus.
Old 10-31-2006, 10:27 PM
Originally Posted by dirtyd0g
...or 5r110 transmission. Those require mercon fluid. ...
Alan
Actually, just a minor point, but the torqshift requires Mercon SP.
Steve
Yes i see that it says that now, but i'm wonderin if the bean counters forced the engineers to say that. Love to talk to someone in ford about it.
Adrianspeeder
Old 11-12-2006, 08:07 AM
jbrew's Avatar
Well heres the TSB. I have a 98 E4OD that requires MERCON III -per manual. MERCON III ? It doesn't exist!! Heck with it, - Using Castrol with a taste of Lubeguard.
The TSB put out last summer converting all "MERCON" known to mankind - 2 MERCON V.
A/T - Mercon V ATF Usage
TSB
07/24/06
MERCON ATF IS BEING REPLACED BY MERCON V
ATF AS A SERVICE FLUID.
FORD:
1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F-B-Series
2000-2007 F-650, F-750
LINCOLN:
1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY:
1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR:
1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE
MERCON(R) Automatic Transmission Fluid is being replaced by MERCON(R) V as a service fluid.
ACTION
Beginning immediately all automatic transmission / transaxle applications requiring MERCON(R) can now be serviced using MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V. After July 1, 2007, MERCON(R) Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCON(R) with MERCON(R) V or MERCON(R) Automatic Transmission Fluid or dual usage fluids labeled MERCON(R) / MERCON(R) V
Old 11-12-2006, 11:20 AM
You are mixin two things up. There is no Mercon III, just Mercon. Which happens to be the same GM fluid spec as Dexron III.
Thanks for the TSB, but I'd like some reasoning behind it from ford.
Adrianspeeder
Old 11-12-2006, 01:11 PM
jbrew's Avatar
Adrianspeeder
WTF, I'm not mixing anything up, So far I have two manuals that say MERCON III -
Haynes & Chiltons has MERCON III listed - I know some of you have a book look it up.
Old 11-12-2006, 04:56 PM
casey_1's Avatar
What manual is that from? There is no such thing as MERCON III, regardless of what's in that manual.
There is MERCON/DEXRON III, and that's where I think the mixup comes from. DEXRON had a III version, but there never was a MERCON III.
Old 11-12-2006, 05:10 PM
jbrew's Avatar
Haynes & Chilton's manuals, MERCON/DEXTRON III ,they just shortened the name along with many others out there (I googled lol) Found allot of articles that had the 4R70W's all get 5 , but mann I'm telling yuh, when it comes to the 4R100/E4OD I can't find a straight answer any ware, I'm not sure anyone knows for sure. As the manuals state MERCON III which is just short for MERCON/DEXTRON III , It's not just "MERCON" What else would reason? Crap!! Maybe it is, Idunno!!
Old 11-12-2006, 08:21 PM
You got it, very common to shortin the ford and gm spec together and make Mercon III, but there ain't no animal from Ford.
Adrianspeeder
Quick Reply: Mercon V used in 4R100
