Re-programming Keyless Entry Keypad
Old 11-08-2006, 10:01 PM
MeanGene's Avatar
Does anyone know how to reprogram the keypad on the drivers side door. I have the Ford code for the door, but I want to change/add my own code.
Old 11-08-2006, 10:44 PM
nigdonht's Avatar
Look at the bottom of page 92 in your owners manual under, Programming A Personal Entry Code, here's what it says:
Programming a personal entry code
To create your own personal entry code:
1. Enter the factory set code (keypad will illuminate when pressed).
2. Within five seconds press the 1 • 2 on the keypad.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. After the code is entered, the locks will cycle, confirming that the new
code has been set.
Tips:
• Do not set a code that uses five of the same number.
• Do not use five numbers in sequential order.
• The factory set code will work even if you have set your own personal
code.
• If you set a second personal code it will erase your first personal code.
Old 11-09-2006, 12:17 AM
MeanGene's Avatar
Thanks, for the info.
Quick Reply: Re-programming Keyless Entry Keypad
