How to check for vacuum leaks?
Old 12-26-2006, 04:20 PM
BigRed125's Avatar
How do you check for vacuum leak in the rubber hose for one of the system idle or fuel controls or an intake leak after the throttle body?
I have a 1998 4.6L V8. If oyu have any pics with arrows for what to check that would be great.
Old 12-26-2006, 05:46 PM
s1037s's Avatar
the scary way is to use carb or brake cleaner and spray lightly around hoses. the safe way is to use a smoke machine to push smoke into the intake while engine is off and it will show you your leak. most likely your leak is the little rubber 90degree elbow behind throttlebody, but i had a broken throttle body elbow bolt that caused mine
Old 12-26-2006, 05:47 PM
bullseye670's Avatar
Spray starting fluid at the hose or area in question. If there is a vacumm leak the engine will start to pick up speed.
bullseye670.............
Old 12-26-2006, 07:11 PM
Hawkpilot's Avatar
Get a few feet of 1/4" vacuum line. Hold one end to your ear, and pass the other end around by the various fittings and hoses. Works like a stethoscope, doc!
Old 12-26-2006, 07:26 PM
Quintin's Avatar
If you've got a propane torch, introduce propane slowly around suspect fittings and connections while the engine is running and wait for the engine's idle to change.
Carb cleaner and/or starter fluid works too, just don't spray around plug wires or ignition coils. And if you do...well, your eyebrows do grow back eventually.
The number one suspect area is somewhere in the PCV tube assembly coming off the passenger's side valve cover to the intake manifold.
Old 12-26-2006, 11:48 PM
BigRed125's Avatar
Thanks for all your suggestions i will do that tomorrow and see what i gets me.
Old 12-27-2006, 11:52 AM
compaddict's Avatar
Pull each line off the source and suck on it. If it does not hold vacuum.. You found the line.
Easy and takes less than five minutes.
Vince
Old 12-27-2006, 01:23 PM
BigRed125's Avatar
What are some of the symptoms of a vacuum leak? I forgot to ask that in thwe beginning.
Old 12-27-2006, 02:20 PM
jbrew's Avatar
PO171, PO174 .
Rough idle..
Air leaking sorta noise
Whistling noise.
Old 12-27-2006, 03:43 PM
BigRed125's Avatar
Originally Posted by jbrew
PO171, PO174 .
Rough idle..
Whistling noise.
It doesnt show any codes. But it has a little of a rough idle. Thanks for oyur reply.
Quick Reply: How to check for vacuum leaks?
