F-250 / Super Duty / Diesel
towing capacity for 5.4L 2v crewcab f-250??????
Old 01-23-2007, 06:15 AM
RDY2RAC's Avatar
i've came across a really nice 01 crewcab 5.4L2v f-250. what was the towing capacity for the 5.4L and could i get away towing about 10,000lbs????
Old 01-23-2007, 06:54 AM
BumperB's Avatar
You could get away with it but I think the rated towing weight is only around 7,200 lbs with the old 5.4. It is not nearly as much as you would think.
Old 01-23-2007, 12:28 PM
adrianspeeder's Avatar
10000 I've done with a F-150, so it'll do it. Just won't be as fast as the 6.8L or the diesels on the hills.
Adrianspeeder
Old 01-23-2007, 01:30 PM
jorlee's Avatar
Courtesy of www.motorcraftservice.com Under Owner Guides, and select vehicle from there.
F-250 w/automatic transmission
Engine Rear axle
ratio
Maximum
GCWR - kg (lbs.)
Maximum trailer
weight - kg (lbs.)1
5.4L 3.73 6 124 (13 500) 4 536 (10 000)
5.4L 4.10 6 804 (15 000) 4 536 (10 000)
6.8L 3.73 7 711 (17 000) 4 536 (10 000)
6.8L 4.30 8 165 (18 000) 4 536 (10 000)
1Conventional/Class IV trailer hitch only. Fifth wheel trailer maximum
weights can be calculated by subtracting GVW from GCWR.
Quick Reply: towing capacity for 5.4L 2v crewcab f-250??????
