Transmission Leaking Bad From Bellhousing
Old 01-28-2007, 08:01 AM
sparkys_97f150's Avatar
ok guys i have 97 f 150 automatic 4x4
my problem is once my tranny gets up to pressure the tranny fluid just starts pouring out of the inspection hole in bellhousing
a while back you guys suggested that my front seal was bad
well i had it changed this past week and that did not solve problem
the guy that did it said that everything looked ok when he had tranny out of truck he changed the seal put everything back togther took truck for ride said it shifted firm etc but when he pulled back to the yard it was still pouring out of inspection hole
ok could he have put the seal in backwards? or am i looking at a bigger problem then a simple seal
any help would be greatly appreciated i have been without truck since november and i am getting to the point of just burning the thing
Old 01-28-2007, 12:30 PM
keith97xlt's Avatar
its a 97 so it has torque converter drain plug . maybye that worked its way loose.
Old 01-28-2007, 03:32 PM
Fire604's Avatar
ditto what Keith said. Check the converter drain plug.
Old 01-28-2007, 05:42 PM
yeah but wouldnt there be evidence of a leak at the drain plug?
Old 01-29-2007, 06:01 AM
keith97xlt's Avatar
you have to take off the rubber plug and spin the converter to get to the actual plug. if thats loose the converter is spinning and pissing fluid everywhere.
Old 01-29-2007, 05:36 PM
the guy that did the work is pulling the tranny out again sometime this week when the tranny is out i will look at the drain plug
anyother ideas as to what may be wrong keep em coming
Old 01-29-2007, 09:38 PM
JMC's Avatar
JMC
JMC is offline
When you pull the tranny you will see where the leak is coming from. Is the oil engine oil or tranny oil?
JMC
Old 01-30-2007, 05:17 AM
its tranny fluid
Old 01-30-2007, 09:54 AM
Jims91's Avatar
Behind the front seal is a bronze bushing the end of the converters rides in. When this bushing is worn it allows the converter to wobble just enough to cause a leak even with a new seal. The bushing itself is cheap but the pump assembly has to be remove and disasembled to replace. Should also make sure there is no grove cut into the sealing area of the converter.
Old 01-30-2007, 01:27 PM
keith97xlt's Avatar
if this guy doesnt fix it right this time, find another tranny guy.
Old 01-30-2007, 04:59 PM
he fixed what he was supposed to!! the front seal
he thought it might be the bushing if it is i will have to take tranny to shop
basically i have the guy removing and re installing tranny thats all
i cant and didnt want to do it my self easier to pay someone
Old 01-30-2007, 06:52 PM
dirtyd0g's Avatar
I hope a front seal takes care of it. I personally highly doubt it. As was mentioned the bushing should have been replaced as well and the converter hub inspected for uneven wear.
Alan
Old 01-30-2007, 07:09 PM
no the front seal didnt fix the problem thats wh yi was re asking about it
he thinks its the bushing the problem is that he cant fix that have to take tranny to shop for it
so basicly i have had the front seal replaced which i didnt need but whatever
and he is going to remove tranny again for me and re install tranny when i get it fixed so far its only cost me 300$ and whatever shop charges me to fix tranny and i havent touched the truck myself
Old 01-30-2007, 08:22 PM
dirtyd0g's Avatar
I've seen this on the 97 transmissions many times. Here is the scenario I usually see. The roller clutch starts to lose parts. The parts make it into the pump and bushing. The trans is on it's last leg. Maybe you have a fluke pump problem or a cracked pump, I however doubt it. Before you do anything more drop the pan and look for unusual parts. It could be cheaper to replace the trans than to repair it and then have to replace it a month later.
Alan
Old 01-30-2007, 08:34 PM
my guy replaced the filter when he had tranny out and said everything looked ok
but ty for heads up
if i need new tranny truck is gone dont have money for it and am losing patientce with it
Quick Reply: Transmission Leaking Bad From Bellhousing
