40/20/40 bench seat "20" removal and addition of console instructions
Old 01-28-2007, 07:11 PM
BtownFord's Avatar
Earlier today I took my middle seat out of my truck and replaced it with a floor console. It was an easy installation and took about 45 minutes with me stopping and taking pictures. Here are the instructions with pictures:
You should start with the fold down console face up and locked as shown:
Pull up hard at the indicated points. If you have never done this it will probably take a fairly decent pull. It should pop right out. After it pops up then slide the seat forward and it will pull out.
Disconnect the 12V outlet plug. On the bottom side is a piece of plastic that you should press down and it should come right out
[IMG][/IMG]
Here are the 4 bolts that you will need to turn counter-clockwise with a T-50 Torx bit. Put some strength into it because mine were a PITA to break loose.
Old 01-28-2007, 07:13 PM
BtownFord's Avatar
2nd post of instructions
After removal of the bolts, pull the console out. This is what it looks like afterwards
[IMG][/IMG]
On the new console, remove the cup holder in the front. This part is optional but it makes it easier to line the holes up. Removed the rubber inserts and to remove the plastic squeeze on both the longer ends in the middle and it should come out.
I couldn't get a good picture, but when you insert the new console in the position, BEFORE inserting the bolts connect the 12V outlet plug to the plug you unhooked earlier.
This pic is of tightening the rear bolts. Continue tightening the bolts up
[IMG][/IMG]
Insert the cup holders back into place
Finished product
[IMG][/IMG]
Old 01-28-2007, 07:17 PM
Looks good and pretty straight forward. I've been wanting to do that mod for a while, but I'm too darn lazy. Is that console one from ebay?
Old 01-28-2007, 07:19 PM
BtownFord's Avatar
Yes its fairly easy and i did purchase it off ebay
I forgot to mention i have more pictures in my gallery under the album "console swap" or something of that nature. It has 21 pictures. I just did a shorten verson as a thread!
Old 01-28-2007, 07:23 PM
top_sgt's Avatar
time to go shopping on ebay!!!!!!!!!!
Old 01-28-2007, 08:30 PM
NASSTY's Avatar
Looks good BtownFord Does that console have a slideout ashtray on the front lower area,near the floor?I was looking at one on ebay and I was just wondering what the slide out thingy was?
Too bad the one on Ebay is all dinged up and too much $$.
Old 01-28-2007, 08:40 PM
BtownFord's Avatar
No, mine does not have the slide out ashtrayin the front. It does have a fairly decent sized pocket in the front. Good for putting wallet, check books and such
Old 01-28-2007, 08:47 PM
NASSTY's Avatar
Thanks for the info and the great write up on the install.
Old 01-28-2007, 08:52 PM
F150DEER's Avatar
nice write up I have 2 ? I assume the 12v power port is still on the back of console. and does the slide out cup holder still work. thanks for the reply.
Old 01-28-2007, 09:41 PM
weadjust's Avatar
I would like to do that to my truck. Where did you get it and how much?
Old 01-29-2007, 09:00 AM
BtownFord's Avatar
Yes the 12v power outlet is on the back of the console. And the slide out cup holder still works.
Old 01-29-2007, 09:01 AM
BtownFord's Avatar
I got mine off ebay last week. There were two on there. One was buy it now for about $245 and the other was an auction. I got lucky and was one of two people bidding on it. I got it for like $140 or so. I would just look on ebay or look on the classifieds from here
Old 01-29-2007, 10:52 AM
YOMAN's Avatar
Can you please snap a pix inside the consele...is it ALOT of room in there??
Thanks!
YOMAN!
Old 01-29-2007, 02:49 PM
4df150's Avatar
I got this for Christmas:
Maybe I'll pull my "20" out and have a place for my beer...
Old 01-29-2007, 08:14 PM
BtownFord's Avatar
Thanks!
YOMAN!
Here is a decent picture of it. This shows from the front to the rear. Imagine if you are standing directly in front of the console looking at it. At bottom of the picture is where the cupholders start and there is storage area underneath the console. There is 4 slots for coins and a decent sized pocket on the lid to hold stuff
[IMG][/IMG]
Quick Reply: 40/20/40 bench seat "20" removal and addition of console instructions
