'06 Hesitation on accel around 40 mph
Old 02-18-2007, 12:39 AM
kuhl0040's Avatar
I know others have had hesitation problems with earlier years, but has anyone had their '06 fixed yet? Is their a TSB for the '06 hesitation problem?
Thanks,
Tyler
Old 02-18-2007, 06:23 AM
svt2205's Avatar
Can you be a bit more specific on the hesitation? My 07 has some strange shudder when lightly downshifting from OD to 3rd as well as other times where it hesitates.
Old 02-18-2007, 11:16 AM
hmfic's Avatar
The TSB's help, but its not a fix. The Edge Programmer fixed mine.
Old 02-18-2007, 01:40 PM
Go explain your concerns to the dealer and have them do a pcm reflash.
Old 02-18-2007, 04:35 PM
kuhl0040's Avatar
When I am at part throttle around 40 mph and 2000 rpm and then try to accelerate, it is like a 2 second delay before the power kicks in.
Old 02-18-2007, 07:04 PM
kdds05screw's Avatar
Just save yourself the aggrevation and just get a tuner. A dealer reflash may help a little but you have no idea what a hesitating slug your truck really is until you tune it. A Troyer custom tune is a good option and will eliminate all hesitation.
Old 02-18-2007, 07:17 PM
TNC's Avatar
TNC
TNC is offline
A tuner will do the trick. My '04 5.4 felt way slower than my '97 4.6. Got my tunes and it's a whole different story. They are that good. XCAL2 and Troyer, btw.
Old 02-20-2007, 01:54 PM
kuhl0040's Avatar
I went to a new dealer with TSB 6-19-03 in hand and they re-flashed the computer and it helped quite a bit. I am still going to get the livewire when it comes out.
Old 02-20-2007, 01:57 PM
a n t h o n y's Avatar
Banned
Livewire is released.
Old 02-20-2007, 03:06 PM
BeyondLimitz's Avatar
Let the dealer take care of you.
Old 02-20-2007, 03:17 PM
Boyd Laing's Avatar
F150 Hesitation
I have an 2006 F150 XLT S/Crew, with a similar hesitation, however, mine is more pronounced on the highway when I want rapid throttle response for passing. I have the 2 second delay when the truck almost feels like it is going to stall out before kicking in, my father has the same effect in his 2005, I thought it was normal? Is this a common problem with F150's?
Old 02-22-2007, 12:14 AM
speedraisor's Avatar
I have a hesitation or miss when maintaining speed under light load... the CEL has actually come on but the dealer can't figure out the problem... it's been rather frustrating, i feel your pain!
Old 02-22-2007, 12:58 PM
kuhl0040's Avatar
Here are the links to NHTSA and the ALLDATA TSB. I just printed out the ALLDATA TSB's and took it to the dealership and showed the mechanic. The NHTSA data does not have this TSB, I don't think it is updated as often as the ALLDATA site. It is TSB 6-19-03 for the hesitation problem.
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
http://www.alldata.com/TSB/20/062017eC.html
Old 02-22-2007, 01:14 PM
When I had my 05, I took the tsb to dealer, they reflashed my TEM7 pcm code up to a BKP1. It was definately better at first ( perminately fixed a rough 1-2 upshift ) until the adaptive set in again then it was back to the hesitation. If I pulled the neg battery terminal for 30 minutes and reset adaptive, it probably would have done the same thing. On my 05 as well as my 06, a tuner was the only thing that totally elimates this.
Old 03-04-2007, 03:08 PM
PhqChevys's Avatar
TSB
06-22-7 UN-COMMANDED TCC APPLY ON THE 1-2 SHIFT CAUSING PERCEPTION OF HESITATION AND/OR LACK OF POWER DURING SHIFT
Publication Date: October 23, 2006
FORD: 2005-2006 Crown Victoria, E-150, E-250, Expedition, F-150
LINCOLN: 2005-2006 Town Car
2006 Mark LT
MERCURY: 2005-2006 Grand Marquis
This article supersedes TSB 06-8-2 to update the Service Procedure and add Service Labor Times.
ISSUE:
Some 2005-2006 vehicles with a 4R70/75E-W may experience an un-commanded torque converter clutch (TCC) apply or TCC partial apply immediately after the 1-2 shift. This may result in the perception that the vehicle lacks power or that the transmission is up-shifting too early. No DTCs are set during this condition.
ACTION:
Follow the Service Procedure for verification and repair.
SERVICE PROCEDURE
Monitor (TCC %) solenoid command state - duty cycle and (TC SLIP ACT) torque converter clutch slippage - RPM, while in 2nd, 3rd or 4th gear with a TCC % reading 0.
If TCC % = 0 and TC SLIP ACT = less than 20 RPM then inspect the number 7 check ball (Figure 1) in the main control valve body for damage. Replace as required following the appropriate Workshop Manual (WSM) under Disassembly and Assembly of Subassemblies - Main Control Valve Body.
Figure 1 - Article 06-22-7
NOTE: THIS PROCEDURE IS PERFORMED IN 2ND GEAR AUTO (NOT MANUAL 2) MONITOR (TC SLIP ACT) AFTER THE POWERTRAIN CONTROL MODULE (PCM) COMMANDS 2ND GEAR AND BEFORE THE VSS READS 35 MPH (56 KM/H).
If you receive any other reading, this TSB does not apply and follow normal diagnostic procedures as outlined in the appropriate WSM.
NOTE: IT IS NORMAL FOR THE PCM TO COMMAND 4TH GEAR AT SPEEDS AS LOW AS 19 MPH ( 30 KM/H) WITH LIGHT ACCELERATION WHEN THE THROTTLE POSITION IS LESS THEN 20%.
PART NUMBER PART NAME
EOAZ-7E195-B Ball Check
1L3Z-7C155-AA Gasket - Valve Body Upper
1W7Z-7D100-AB Gasket - Valve Body Lower
XT-5-QM MERCONŽ V Automatic Transmission Fluid
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
062207A 2005-2006 Crown Victoria/Grand Marquis/Town Car/Econoline/Expedition: Includes Time To Inspect, Diagnose, And Repair (Do Not Use With 12650D, 12650D45, 12650DX1, 12650D81, 7191A, 7191A1, 7000A13, 7191A2) 2.3 Hrs.
062207A 2005-2006 F-150/MarkLT: Includes Time To Inspect, Diagnose, And Repair (Do Not Use With 12650D, 12650D45, 12650D81, 12650DX1, 7191A, 7191A1, 7000A13, 7191A2) 2.2 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
7E195 01
Quick Reply: '06 Hesitation on accel around 40 mph
