2002 F150 Super Crew Radio Removal
Old 03-09-2007, 12:33 PM
lookingdeep8's Avatar
Hi,
After I take off the dash panel around the radio/cd player, how do I get the unit out? I want to add the SIRIUS bypass unit so I don't have to use the FM transmitter which sucks in my area anyway.
Russ Brick
Miami, Florida
Old 03-12-2007, 06:51 PM
Bikerboy4life's Avatar
U need too push something into all four little holes on the front
There is a special tool for it.
Or you can try using 4 allen wrenches, push in and push sideways away from the radio at the same time and pull radio out.
The tool makes it easier
any stereo shop would have the tool
Old 09-15-2009, 10:21 PM
risshin's Avatar
Don't know if your still around, I thank you for this information. I was having a heck of a time removing the radio.
Old 09-17-2009, 12:57 PM
NJCrew's Avatar
Question Where did you mount it?
Does anyone have pics of where they mounted their Satellite radio in a 2002 Supercrew? I'm looking to do a clean install, but there appears to be limited options to hide wires, etc.
Old 09-17-2009, 02:20 PM
Sundevil2188's Avatar
What sirius tuner do you have?
Old 09-17-2009, 04:36 PM
thejake1989's Avatar
pics will help out alot. to make it easy go get a new radio that is sirusxm ready and get the tuner for that thay way you can hide it like mine
Old 10-02-2009, 11:07 AM
F150RYDER2K8's Avatar
This is what you need to pull that radio out. Stick these in each side in those four holes. Pull the left one to the left and the right to the right and then pull straight out, that radio will slide right out. It is so simple. I actually picked mine up at Pepboys. Unfortunatly my new truck was not as easy to get the stereo out.
http://www.sears.com/shc/s/p_10153_1...0070921x00003a.
Old 10-03-2009, 06:21 PM
Red02FX4's Avatar
A metal coat hanger works just as well. cut the 2 ends off at about 4" from tip to make a nice U.... and is cheaper
Old 10-05-2009, 05:56 AM
I tried the coat hanger and didn't have any luck because there are 2 little notches on the end of the tool. I think I only paid about $5.00 for mine and just keep them in my toolbox.
Quick Reply: 2002 F150 Super Crew Radio Removal
