How to turn off Check Engine Light
Old 03-16-2007, 10:18 AM
Johnex1's Avatar
I changed one of my COPs last night. It was coil #5 and now my engine runs great. However, the check engine light is still on. How can I turn it off?
Thanks,
John
Old 03-16-2007, 10:19 AM
Camarothatcould's Avatar
take it to any autozone. They will do it for free
Old 03-16-2007, 11:04 AM
worland's Avatar
If you actually fixed the problem, it should turn itself off. If memory serves me correctly (and it probably doesn't) the local repair shop said to me many years ago you had to have 5 starts and drive at least 40 some-odd miles for the light to clear (or something along those lines).
Or, go to Autozone.
Or, go to Harbor Freight on-line and buy a $40 code reader. It'll reset the light.
Old 03-16-2007, 12:15 PM
Andy-jr.'s Avatar
unhook your battery for a while, That should clear the code.
Old 03-16-2007, 01:15 PM
jbrew's Avatar
You shouldn't have a light if you followed the correct procedure with a COP changout.
Step 1 - Disconnect Neg terminal on battery..
Old 03-16-2007, 01:32 PM
projectSHO89's Avatar
If you unhook your battery now, you'll have to reprorogram all your radio stations.
Just look in your owner's manual for the fuse layout. Locate the fuse for "PCM". This is usually a 5A or so fuse. Pull it and wait 15 minutes. Reinstall it and allow your PCM to relearn parameters.
exactly which fuse varies by model year which you failed to provid. For example, on a 97, it's in the underhood mini-fuse box. A 2000 uses F2 in the underdash fuse panel, etc.....
Anyway, just look in your owner's manual.
Steve
Old 03-16-2007, 01:42 PM
SlammaJamma's Avatar
Fix it
Quick Reply: How to turn off Check Engine Light
