Install a second battery?
Old 04-18-2007, 08:56 AM
martyapo's Avatar
I'm thinking about adding a second battery to my system but have no idea how to do this properly. Can someone tell me how to wire it and where to mount the battery. Off the top of my head, I was thinking that a good place to put it would be inside my truck box. Could I then run the power wire through the bed into the cab? Then how do I wire it into the system?
Old 04-18-2007, 09:05 AM
Impact9's Avatar
http://www.bcae1.com/battiso.htm
Basic Car Audio website, hit the home link and add to favorites.
Old 04-18-2007, 12:43 PM
martyapo's Avatar
So if I go with the easier "dual battery with no isolator" my alternator will still charge the 2nd battery? Do I wire the positive (from battery #2) directly to my distibution block? So I then would have 2 positive inputs (1 from each battery) to the distribution block and then 1 positive output to the capacitor. Sound right? Also, any suggestion for routing the power wire? Would it still be a good idea to place the battery in my alluminum truck box and drill through the bed and cab? My amps and capacitor are mounted on the back of the cab wall.
Old 04-18-2007, 02:36 PM
Impact9's Avatar
Yes it will charge. I've done it in the past on a 88 T'Bird and I just wired the postives of the batteries together and grounded the second battery to the chassis. It works fine that way and it's basically the same thing they showed on bcae1.com.
Far as where to put them, I don't know. There is are battery relocation kit available to put the battery under the truck on the frame and it was too pricey for my taste. I would just get a plastic battery box and a lot of 0 gauge wire with connectors and put it in the bed like you want. Be sure to use fuses on both batteries. Last thing you want to do is fry everything.
Old 04-18-2007, 08:33 PM
martyapo's Avatar
Thanks for the great link and advice. Much appreciated.
Old 04-19-2007, 01:58 AM
Impact9's Avatar
no problem, gotta post some pics when you start this project.
Old 04-20-2007, 01:22 AM
nothinbutaford's Avatar
Why do you want to add a second battery? If its for extended play with the truck off you will want to use a high power relay so when the second bat goes dead you still have the first to start back up with. If you are havin a power loss problem from your stereo a second battery will only make it worse.
Old 04-23-2007, 05:48 PM
ranchocucbro's Avatar
The only reasons you should need a second battery are:
1. extended play with the engine off
and/or
2. SPL competitions with uprated alternator(s).
Old 04-24-2007, 06:32 PM
travis08's Avatar
Im going to be adding a second battery next month with a battery isolator im going to have a yellow top mounted under the bed of my truck and a red top mounted in the stock position and im installing a High output alternator im going to be hitting at least 160 Db. when i gert finished with my truck next month
Old 04-24-2007, 08:14 PM
Bartak1's Avatar
Hope you have a lot of big plans, your a long way from a legal 160
Old 04-24-2007, 08:20 PM
travis08's Avatar
2000$ worth of big plans lol
im droppin my truck off for a full week
to do tons of crap
Old 04-24-2007, 11:04 PM
Impact9's Avatar
Just $2k? I got $1k in my headunit alone lol. Seriously speaking save the money on labor and diy. Better chance of hitting your goal.
Old 04-25-2007, 12:36 AM
Bartak1's Avatar
Agreed if you can do it yourself. Having a 160+ db. system installed by a shop will cost an arm and a leg...if it can actaully do 160+.
Old 04-25-2007, 06:56 PM
travis08's Avatar
well im sponsored by my shop thats why its so cheap
Old 04-25-2007, 08:21 PM
Bartak1's Avatar
Ahhhh, lucky duck
Quick Reply: Install a second battery?
