EGR exhaust tube wrench size PLEASE !!!
Old 04-22-2007, 09:40 AM
Lou Colmo's Avatar
Was going to clean the EGR valve but I can't get the nut off of the back of the EGR valve. Does anyone know what size it is. I know it's bigger then 1/2 inch.
Old 04-22-2007, 09:44 AM
Quintin's Avatar
1-1/16".
And the ports in the throttle body are what need cleaning, usually not the valve itself.
Old 04-22-2007, 09:51 AM
Lou Colmo's Avatar
Thanks, So can I assume that I can just disconnect the EGR valve from the throttle body and remove the throttle body without removing that exhaust tube nut from the EGR ?
Old 04-22-2007, 10:00 AM
torkum's Avatar
I would recommend disconnecting the EGR tube nut first then the 2 bolts holding the EGR to the throttlebody elbow, then take the elbow off. With the 1 1/16" wrench you should have plenty of leverage. Clean it all and be careful with the gaskets when taking it apart.
Old 04-22-2007, 10:41 AM
Quintin's Avatar
Yeah, that's what I do. Remove the 10mm bolt and stud holding the valve to the throttle elbow and leave the valve attached to the EGR tube.
Old 04-22-2007, 12:05 PM
Lou Colmo's Avatar
All done. I borrowed a wrench but couldn't get the nut loose so I just diconnected the EGR from the tb then removed the tb . Both ports were completly clogged. Seems to idle smoother now( maybe it's just me). Can I expect any mpg improvement ??
Quick Reply: EGR exhaust tube wrench size PLEASE !!!
