2003 FX4 Rims fit on my '97 F150???
Old 06-23-2007, 05:59 AM
syoung_2000's Avatar
I have a 1997 F150 and am looking for something that is a stock rim and bigger than my 16" rims.
I am not interested in Harley Davidson or Lightning rims (wouldn't look right on my truck IMO)
I think the FX4 rims on 2002, 2003 are 17" ??? I DO know that they look better than my rims. Also there are some King Ranch rims on the Heritage Editions that are bigger???
So does anyone know if these will work?
Also, if the FX4 rims had stock tires would it change my speedometer or does the outer tire diameter remain the same as what I already have?
Thanks everyone!
Old 06-23-2007, 06:10 AM
polpilot's Avatar
All the 5 lug f150 from 1997 to 2004 will fit. And i know ford put 17s on some f150s but im not sure witch ones, the biggest stock rims for the 97-04 where the 18s on the Lightnings. hope i helped.
Old 06-23-2007, 07:19 AM
svt2205's Avatar
In 99, I think, Ford changed the wheel stud size. Can't remember from what to what, but it was smaller to larger. With that, you can go with later year rims on earlier trucks, but your limited going the other way.
And the largest factory rim on 97-04 Heritage trucks is the Harley rims which were 20's
Rim size has nothing to do with the speedometer. It's tire size. If you go with a tire that has the same OD as your originals you don't need to do anything. Plus if your only stepping up a size or 2, the error in the speedo isn't large enough to worry about.
Hope this helps
Old 06-23-2007, 10:17 AM
wandell's Avatar
Like they mentioned, the bolt pattern is the same, but the stud size is different. If you use wheels from a newer truck, you just need to use lugnuts for a 97 truck.
Old 06-23-2007, 03:15 PM
okay
Old 06-23-2007, 09:42 PM
wandell's Avatar
We can't answer without knowing you OEM tire size. Just guessing, I doubt the 17's have the same height tires. The FX4's came with 265/70-17's (32x10.50) and I don't think there was a 16 inch tire that tall(from the factory).
Old 06-24-2007, 12:39 AM
My factory rims are 16".
The tires I have on are 235/70-16
Maybe I'm not wording this right.
Say you have a brand new 2003 FX4 with factory rims and tires. I know the 17" rim I'm thinking of is obviously 1" bigger. I also realize it obviously takes a different size of tire.
The question is: If you were to measure the diameter of my tires and the diameter of these tires I'm looking at, would they be the same. If different how far off would they be?
I'm looking at rims similar to these:
http://cgi.ebay.com/ebaymotors/ws/eB...m=270135046680
If I just had to use my studs, would the wheel be on there tight and solid?
Sorry for all the questions
Old 06-24-2007, 02:30 AM
FordScrew24's's Avatar
I have those wheels and tires with 1500 miles on them in my storage unit. Email me for some pricing details. They are off of my old 2003 FX4, 5x135.
Old 06-24-2007, 09:32 AM
wandell's Avatar
Yeah, you just needed to tell us your tire size so we could compare it to the OEM tires from an FX4. And yes, the OEM size (265/70-17) is a good bit taller than your tires. The OEM FX4's came with tires that are almost 32 inches tall. Your 235/75-16's are only 29 inches tall.
And yes, you will be fine mounting those wheels as long as you use lugnuts for a 1997 F-150.
Old 06-24-2007, 03:28 PM
Flyboy60's Avatar
What do the numbers mean 275 = height, 17" = rim diameter but the 70 = ??
I just bought this truck and got it painted. had all the wrong tires on it - I think they took off the good tires and sold it to me like what you see here.
https://www.f150online.com/galleries...cfm?gnum=10009
I would like to know,what are the largest tire I could put on this baby without rubbing - MUD or All Terrain?
Old 06-24-2007, 03:47 PM
wandell's Avatar
275 is the width of the tire in millimeters. 70 is the aspect ratio or the relationship of the height and width.
You are right, you do have a thrown together set. I'd be shopping for a nice set of 22's or 24's with your truck. They would look sweet with the Navigator conversion!
Quick Reply: 2003 FX4 Rims fit on my '97 F150???
