How do you replace fuel injectors?
What is the procedure for removing and replacing fuel injectors?
My SCed '97 4.6L is about to enjoy a (hopefully) significant boost in performance when I receive the 90mm MAF, 42# injectors and custom tuned XCal2 from Troyer in a couple days. I just don't have a clue how to change out the injectors.
Not much to really - disconnect the battery , take the TB cover off, take off the intake,disconnect the electrical connectors unbolt the the fuel rail, bleed the pressure via schrader valve on the rail, lay some rags/paper towel around the injectors to catch residual fuel - pull the rail.
Pull the injectors that stick in the rail out , just pull them , there held in with and o-ring.
Now when you pull the injectors , make sure you have all the hats - sometimes the hats will come off and stick in the manifold.
Revers order for install.
Good Luck
Good Luck
