*****AC compressor Clutch******
Old 10-02-2007, 12:56 AM
tedontheweb's Avatar
I have a question conserning my 97 5.8.
The clutch on the AC compressor will click on and of repeatedly making a loud clicking sound at low RPM
If I turn the switch on the dash to off the clicking stops. I am wondering weather i should go about replacing the clutch/pully or if i need to add R-134
The AC works fine but the clicking is making me think I need to get this fixed before the cold Alaska winter sets in(LOL) Advice?...
PS Anyone have a cluch diagram or breakdown
Old 10-02-2007, 10:06 AM
projectSHO89's Avatar
Ford didn't put a 5.8 into any 1997 F150s.....
Short cycling compressor clutch is a sure sign of a low charge. That means you have a leak in the system that should be repaired before recharging.
The stock clutch plate can separate and cause a very loud click when engaging/disengaging, often accompanied by a rattling while disengaged. The outer clutch hub is available from Ford for around $50-60. you can look up the correct part number at www.motorcraft.com
For a 97 with a 5.4 (at least), the correct replacement is YB-3020. Do NOT purchase the after market POS from AutoZone.
Steve
Old 10-02-2007, 09:54 PM
Bent6's Avatar
Steve
It could be a 5.8 in a '97 if it is a Super Duty (old body style). You may just have low charge. My clutch wore. It wouldn't engauge at al unless I bumped the face with the ac on and the engine running. I lapped the shim down about .045", and it's worked fine for the last 30,000 miles.
Old 10-03-2007, 12:03 AM
Thanks I will start by adding some pressure with an elcheapo recharge kit.
See if i loose pressure over a couple of days and go from there.
My bad it is a 5.4.
Old 10-09-2007, 09:55 PM
Not the real Problem
OK so I checked the r134 pressure and it is good and holding but i am still getting the clicking from the AC clutch. Should I go ahead and pul;l the clutch assembly or do you think I should try something else.
BTW it only starts clicking when the vehicle is warm.
Old 10-09-2007, 11:40 PM
Photog95's Avatar
It's like $10-$15 for a pressure switch. I would get a new one and see what happens.
Old 10-10-2007, 07:19 AM
You need to focus on describing the EXACT fault.
Sounds like it's just a noisy clutch, however, your posts are not clear as to whether the system is otherwise working correctly. A pressure cycling switch won't do anything for a noisy clutch.
Steve
Quick Reply: *****AC compressor Clutch******
