97 F150 AC Compressor will not kick on.
Old 10-03-2007, 06:51 PM
r0berth1's Avatar
I checked the fuses and freon level. I can not get to compressor to kick on. Blowing hot air. Help.
Forgot to add this. It is the 4.6L
Old 10-04-2007, 06:59 AM
projectSHO89's Avatar
How did you check the "freon level" and what was the static pressure reading?
Steve
Old 10-04-2007, 11:19 AM
zziggy's Avatar
assuming that you are correct the Freon level is OK (By bypass the Clutch Cycling switch on the Accumulator)
Then you can have a Bad Compressor relay, a bad Hi-pressure switch, a Bad compressor clutch coil or an open (broken wire or bad terminal) circuit.
Old 10-05-2007, 09:02 AM
His truck doesn't use a relay on the clutch. The clutch coil is switched directly by the cycling switch or disabled by the high pressure cutoff switch.
Steve
Old 10-05-2007, 09:21 AM
r0berth1's Avatar
I have the r134a pro gauges. I don't remember what the reading was. I will get it this afternoon. I checked the cable, terminal looks good, no burnt spots or arch spots, also wires are not broken.
Old 10-07-2007, 03:24 PM
r0berth1's Avatar
it is reading 106PSIG on both the Low and Hi side. I have replaced the clutch already and that was not it.
Old 10-08-2007, 07:00 AM
Your system is well charged.
You probably have an electrical problem. Disconnect the clutch cycling switch and install a jumper into the harness connector. If the clutch now engages, replace the switch. Otherwise, let us know and we'll wlak you though the circuit check.
Steve
Old 10-16-2007, 06:39 PM
r0berth1's Avatar
Got it working, thanks
It was the clutch cycling switch that was bad. Thanks again for your help.
Old 10-31-2007, 02:50 AM
supraisthebest's Avatar
Steve
where is the "clutch cycling switch" located? I seem to have the same problem.
Old 10-31-2007, 03:40 AM
Shinesintx's Avatar
Yeah, where can I find that.
Old 10-31-2007, 08:28 AM
It screws into the top of the aluminum accumulator can mounted on the firewall, just below and towards the truck center from the plastic cover over the mega-fuses and the starter relay.
You will probably have to remove that cover and move some harnesses around to get to it.
Steve
Old 11-01-2007, 08:46 PM
Bent6's Avatar
My truck had the same issue. The clutch had worn and the air gap was too big for the electomagnetic clutch to overcome. I lapped the shim down about .030", and it's been fine for about 2 years. You will find some info on this in this forum.
Quick Reply: 97 F150 AC Compressor will not kick on.
