Tire Pressure with 35's
Old 11-27-2007, 06:46 PM
CRF250rider1000's Avatar
What tire pressure should I be running with 35" KM2's on stock 18's? Costco set them at like 32 psi when I checked with the accugauge, I thought it should be more like 40psi??
What do you guys think would get the best treadwear and mileage?
Thanks!
Old 11-27-2007, 07:01 PM
kingfish51's Avatar
Thanks!
Run them at 38 to 40. All the 35" tires they have listed on the BFG KM2 site are a load range D tire with a max of 50. 32 is way too low for that tire. I would never go lower the 35-36 on that tire.
Old 11-27-2007, 07:03 PM
Grubrunner's Avatar
If they're a mud terrain, which I believe they are, then I'd run them at 42-44PSI.
I ran my Toyo MT's in the low-mid 30PSI range for a very brief while until I was advised on these boards to run them at 42-44PSI and the ride difference, instantly, was very noticeable.
I'm now running them at about 45PSI.
Old 11-27-2007, 07:08 PM
Sounds good thanks guys!
Quick Reply: Tire Pressure with 35's
