98 4.6 vacuum leak?
Old 12-31-2007, 11:21 AM
98f150guy's Avatar
Question 98 4.6 vacuum leak?
When I'm at a complete stop and have all accessories turned off there is a loud whining noise coming from the middle of the dash. I'm guessing that it is actually coming from the engine compartment. Has anyone experienced this on their truck? It's a 98 4x4 with the 4.6. Could I have a vaccume leak somewhere and thats what the noise is?? If I put the engine in park is seems to go away but then it comes back when in drive and not moving. When the engine is under load. Any ideas??
Old 12-31-2007, 10:52 PM
torkum's Avatar
Possible vacuum leak going to one of the actuators in the dash.
Old 01-01-2008, 07:22 AM
jbrew's Avatar
Turn the selector to "vent". Still here it?
If so - The 98 Vacuum lines plug-in is visible and easy to get at under the dash. if you look in the right spot . Sitting in the driving position about 4" above your right ankle to right is a plug-in with 4 or 5 different colored lines. Check that for leaks.
Old 02-12-2008, 07:55 PM
98f150guy's Avatar
Well I took it in to the Ford dealership and they said the noise I'm hearing is normal and that it was coming from the IAC Valve. Normal my A$$. Nothin but crooks!
Old 02-12-2008, 08:03 PM
jbrew's Avatar
Do you have an after market intake? Well , IAC 's do make noises . But you said a "whine" - The don't whine that I know of.. I take that back , they do whine when its colder than sh^t out side lol.
When they do whine in that circumstance, it almost sounds just like a bad power steering pump lol .
Read This -
https://www.f150online.com/forums/sh...d.php?t=320754
Old 02-12-2008, 08:25 PM
jbrew's Avatar
Old 02-12-2008, 09:02 PM
98f150guy's Avatar
No thank god. Mine is more of a whistling sound. Can hear it at a stop light inside the cab, but as soon as I give it gas, it goes away. :o And yes I do have an aftermarket intake.
Old 02-12-2008, 09:10 PM
CRASH594's Avatar
My 97 had pinhole in the lines that run from the engine to just behind the battery. I found them by keeping the engine running and spraying the lined with a squart bottle. When the sound stopped for a second and returned I looked in that area.
Old 02-12-2008, 09:47 PM
jbrew's Avatar
The dealership said it's the IAC . You do believe them right ?
Old 02-13-2008, 02:01 PM
TheCure's Avatar
Read This -
Sweeet, I have this noise and I think you are right about that....It only happens when its around 0'f ive noticed.
Quick Reply: 98 4.6 vacuum leak?
